Old 10-04-2020, 11:22 AM   #1
jim Trimble
Default 1929 model a ford motor
Changing the oil pan gasket and seal on my motor and I was wondering how can a person tell if he has an insert motor or Babbitt motor . The oil pan is off
jim Trimble is offline   Reply With Quote
Old 10-04-2020, 11:43 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: 1929 model a ford motor
Babbit will have material on the side of the bearing saddle. Inserts I don't think have that.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-04-2020, 03:41 PM   #3
eagle
eagle's Avatar
Either way, now would be a good time to pull the caps and check the bearing clearances. Plastigage works good for this. Make sure to mark them when you remove so you get them back on the right journal and the right direction.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
