09-19-2020, 08:32 AM | #1 |
'40 Ford visors
The driver side visor in the '40 coupe is very stiff, probably hasn't been moved for years. It is hard to flip it up & down. I tried moving it back and forth a number of times, but it's still stiff. I don't want to break anything or use a lubricant that would damage the visor covering as it is great condition.
09-19-2020, 08:37 AM | #2 |
Re: '40 Ford visors
Better than it flopping down while driving. I'd leave it alone and normal use will probably loosen it up over time.
09-19-2020, 09:35 AM | #3 |
Re: '40 Ford visors
If you decide to work on it to make it flip easier, I suggest unscrewing the entire visor and gently work with it on a nice clean cloth on your work bench. Then reinstall. I haven't flipped mine down since 1988 so I imagine it's pretty snug.
09-19-2020, 10:19 AM | #4 |
Re: '40 Ford visors
To make my 40 coupe driver's side visor "stiffer" I pulled the visor straight off the rod (there is a pointed rod in that goes in the length of it) and put a slight bend in it, pushed the visor back on and it now stays where I put it. Yours may be rusty, work it back and forth and pull it off and clean the rod. As mentioned, best done off the car.
09-19-2020, 06:10 PM | #5 |
Re: '40 Ford visors
