Old 09-14-2020, 06:30 PM   #1
Standing Elk
Default interior tacks
So, on say a coupe, when you install the tack strips above the doors and down along behind the doors to hold the wind lace in place how do you hide the heads of the tacks?
Standing Elk is offline   Reply With Quote
Old 09-14-2020, 07:22 PM   #2
kbinde2
kbinde2's Avatar
Default Re: interior tacks
Don't the interior panels (ie, quarter window, and the strip above the door) once installed cover the tack strips (and tack head).?
I looked on my '29 Coupe and have a hard time locating a tack, even in the headliner, the material should hide a staple or tack.. kb
kbinde2 is offline   Reply With Quote
Old 09-15-2020, 10:22 AM   #3
duke36
Brads with the smallest heads possible are most often used to go thru the (fabric) upholstery just enough to hold the "cardboard" panel to the wood, or backing strips on some cars. Then an upholstery needle is used in the hole left by the brad to pull the upholstery fabric out enough to clear the panel. If the brads are driven too hard or deep, that may tear the fabric.
duke36 is offline   Reply With Quote
Old 09-15-2020, 10:36 AM   #4
100IH
Exactly the way I have done it. Staples are fine for the windlace so as not to get in the way when nailing down the cloth covered Card material. Small heads at this point to ease the cloth over the nail, then the last bump to snug it.
100IH is offline   Reply With Quote
