Old 09-14-2020, 09:25 AM   #1
First time restorer
Default Temperature wire
I need to remove the temperature probe from the head cover so I can remove the headcover. I can’t get it loose from the head and I don’t want to take the dashboard apart. Can the wire be cut and spliced back together?
Any ideas?
Thanks
First time restorer is offline   Reply With Quote
Old 09-14-2020, 09:42 AM   #2
rockfla
rockfla's Avatar
Default Re: Temperature wire
I, for one am very confused as to what you are asking? It would help to answer the following questions.....
1) What year car/flathead are we talking about?
2) Do you mean that you are trying to remove the "temperature sender" unit from the head?
3) Pictures are worth 1000 words!!!!
4) Why would you think that you have to dismantle the dash to remove something from under the hood?
5) pictures are worth 1000 words!!!
6) Don't know what you mean by "Head Cover"?? Do you mean the "Head"???
Regards Rockfla
Old 09-14-2020, 09:52 AM   #3
First time restorer
The temperature sender on a 39 flathead ford
Old 09-14-2020, 09:58 AM   #4
rockfla
rockfla's Avatar
You should have just one sender, or at least my 39 Mercury does. It should have a screw in the center of the sender See attached) that hold the wire to it??? You should be able to just loosen the screw and remove the wire??? NOTE Second picture top left.
Old 09-14-2020, 10:04 AM   #5
rockfla
rockfla's Avatar
As for the :"removal", you may be dealing with some electrolysis issues from dissimilar metals, heat and friction. Try using a good penetrating type oil, a few applications over a period of a day or so and letting that soak in. ALSO "sometimes" IF you ever so slightly tighten it before you loosen it, that can also help.
Old 09-14-2020, 10:10 AM   #6
Mart
Mart's Avatar
Are you talking about a mechanical gauge with a capillary tube? If so no you can't cut it.
If you are not sure of the correct term for a thing, try and post a picture, we can help if we can understand what you are trying to do.
Mart.
Old 09-14-2020, 11:24 AM   #7
marko39
These can be stubborn to remove. After removing the nut the tube can be stuck in the well. Just carefully work it back and forth trying to wiggle it until you can pull it out. Soak it with penetrating oil first.
marko39 is online now   Reply With Quote
