08-29-2020, 08:58 AM | #1 |
front tire wear
On a friend's '29 roadster the right front tire shows significant wear in the center and towards the outside of center. Outside tread is OK. Checked the toe in and it is 1/16" + so that is good. Left front tire is OK. Suggestions as to his problem ? Thanks. Bill
08-29-2020, 09:55 AM | #2 |
Re: front tire wear
Check the camber on that wheel.
08-29-2020, 10:17 AM | #3 |
Re: front tire wear
Center wear often indicates over inflation. Is the pressure around 35 psi ?
08-29-2020, 10:38 AM | #4 |
Re: front tire wear
What kind of wear ? Any feather-edge or scallop ?
You can look from the front of the car and see the camber, but, it doesn't really sound as though you have a camber issue. 1/16" of toe-in is OK. I too was thinking tire pressure. 35# is correct. It could also be a bad/defective tire. |
08-29-2020, 02:05 PM | #5 |
Re: front tire wear
Sounds like too much pressure to me, is the gauge accurate?
Charlie Stephens |
08-29-2020, 02:34 PM | #6 |
Re: front tire wear
08-29-2020, 05:22 PM | #7 |
Re: front tire wear
Pete,
heavy tire wear on the outside indicates that the toe-in is too large. But then correctly on both sides. If only one side wears on in or out side, this is an indication that something is warped on the suspension.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
08-29-2020, 09:59 PM | #8 | |
Re: front tire wear
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
08-30-2020, 06:40 PM | #9 |
Re: front tire wear
I agree - the axle needs a tweek but obviously, it is the LHS that is more commonly bent here. (The kerb side)
