Old 02-11-2011, 03:14 PM   #1
JM 35 Sedan
JM 35 Sedan's Avatar
Default Need help to ID this radiator
I have this unidentified Ford V8 radiator that came with some parts that I purchased years ago. Can anyone tell me what year/model Ford V8 this radiator will fit? Thank you!
John
Old 02-11-2011, 03:29 PM   #2
larry/Texas
Default Re: Need help to ID this radiator
It looks like 33-34 Ford car radiator. The bracket on top around the water inlet is used to mount the grill top and support rods to the firewall.
larry/Texas is offline   Reply With Quote
Old 02-11-2011, 05:45 PM   #3
Lawson Cox
Lawson Cox's Avatar
I agree with Larry.
Old 02-11-2011, 05:54 PM   #4
David J
David J's Avatar
Question Re: Need help to ID this radiator
The bottom plate on 33-34 passenger car radiators is riveted and soldered to the bottom tank . This one is not . The rest looks normal ??????? The upper grille brackets look like normal 34 car ! Maybe someone messed with the bottom plate ? David J
David J is offline   Reply With Quote
Old 02-12-2011, 12:02 AM   #5
Pothole Jim
Pothole Jim's Avatar
34 Car radiator. 33 would have hood corner pockets formed into the top of the steel brackets.
Pothole Jim is offline   Reply With Quote
Old 02-12-2011, 12:35 PM   #6
JM 35 Sedan
Thanks for the help guys! Someone else told me that it was a '34 radiator but I wanted to pass it by some of you to confirm. I rescued a very rough 35/36 Ford PU about six years ago and the owner gave me that radiator when I bought some other parts that he had. He said it came out of the PU but I wasn't sure if he was serious or not.
John
