Old 08-23-2020, 06:15 PM   #1
53_mercLuke
Default 1953 Flathead acceleration issue
I'm having issues on acceleration, it just spits and sputters. I have replaced the 6 volt to a 12 volt system 2 years ago, this started happening about 3 months ago and I have been chasing my tail. I rebuilt the carburetor (teapot) and had the alternator rebuilt because it wasnt charging. Still was running bad. Replaced the fuel pump with an electric pump and checked pressure, im getting 3-1/2 to 4 psi which I think is good. I replaced the spark plugs, cap, rotor, ignition coil and went through all the wiring again. It still to me seems like a fueling issue but im.not sure what else to check or replace? Thanks for any advice I can get on the issue.
53_mercLuke is offline   Reply With Quote
Old 08-23-2020, 06:25 PM   #2
Gick70
Default Re: 1953 Flathead acceleration issue
Distributor Vacuum canister,this was what was wrong with mine,a hole in the diaphragm..
Gick70 is offline   Reply With Quote
Old 08-23-2020, 06:26 PM   #3
JSeery
JSeery's Avatar
The fuel pressure is a bit high, should be more like 2 to 2 1/2 psi. That could cause an issue. Also, I am assuming it still has the original vacuum only advance distributor? Are you sure the advance is working? When you say you replaced the cap, is that the distributor cap or the capacitor? A bad capacitor and/or coil is a common issue as some of them are bad from the get-go.
Old 08-23-2020, 06:38 PM   #4
53_mercLuke
I replaced the distributor cap and the capacitor when I did the points. And i did replace the vacuum advance canister but thats another issue, when its hooked up it cranks but doesn't start
Old 08-23-2020, 07:19 PM   #5
F-ONE
F-ONE's Avatar
If that's not hooked up, the engine will have no advance.
F-ONE is offline   Reply With Quote
Old 08-23-2020, 07:26 PM   #6
scicala
scicala's Avatar
Also, it shouldn't make a difference cranking and starting the engine with the distributor vacuum line connected or not connected, since there is not really any vacuum when you're cranking over anyway.
Sal
Old 08-23-2020, 07:49 PM   #7
JSeery
JSeery's Avatar
Think you may be onto your problem here. Without the vacuum connected the engine is going to run poorly and if connecting it causes starting issues something is amiss with the distributor.
Old 08-23-2020, 08:21 PM   #8
53_mercLuke
I never had the advance hooked up before and it ran great. But yeah now if I hook the advance line up before start it just cranks, if i hook it up while running it dies
Old 08-23-2020, 08:32 PM   #9
JSeery
JSeery's Avatar
About the only way I can think of that it would run great with the vacuum disconnected is that the distributor is way advanced. Think of all the time and money you have spent on parts! I think it would be much better to get the distributor working correctly. It can not possibly be working correctly without the vacuum advance working, it is just setting at a fixed timing point. This type of distributor has to have the vacuum to work. So, something strange is going on if you can get it to run without it. Again, my guess would be that the distributor is way over advanced so that it would sorta run once the rpms were up. Regardless, the distributor is not function correctly.
Old 08-23-2020, 08:56 PM   #10
53_mercLuke
Thanks I will check that out. It is strange it ran for about 5 years without. But it is about the only thing I haven't looked to far into
Old 08-23-2020, 09:10 PM   #11
JSeery
JSeery's Avatar
That is strange, you may have a whole new drive experience with the distributor working!
My suggestion would be to send it to one of the distributor guys here on the Barn and have them check it out. A question, how have you been setting the timing?
A past thread on the Loadamatic distributor: https://www.fordbarn.com/forum/showt...5865&showall=1
A side note, Bubba no longer does the Chevy conversion distributors, but other do if you were ever interested.
Old 08-23-2020, 11:53 PM   #12
51 MERC-CT
51 MERC-CT's Avatar
(Try this again)
If the accelerator pump is not in the outer (winter) position, move it there.
If there is an improvement, that is an indication of a faulty accelerator pump and needs replacing.
Also check float level.
Old 08-24-2020, 08:00 AM   #13
53_mercLuke
I have been as of late to see if it helps and I get it spot on but still runs horrible
Old 08-24-2020, 10:33 AM   #14
Ross F-1
Ross F-1's Avatar
There is a wire under the points plate that often times wears thru its insulation, as it moves every time there iis a change in advance. I wonder if it shorts when you hook up the vacuum but doesn't when in the resting position? It's the red wire below.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-24-2020, 11:37 AM   #15
tubman
tubman's Avatar
I had that happen on an MG Magnette I had years ago; it was a bear to find.
Old 08-30-2020, 04:15 PM   #16
53_mercLuke
Update, I found the ground wire in the distributor only holding together with a couple strands of wire. Fixed that and reset timing, runs alot better but still have some stumbling on acceleration more at higher rpms though so I'm still trying to figure out whats going on there but im happy im getting closer to a good running flathead
Old 08-30-2020, 05:54 PM   #17
Aarongriffey
I had a problem earlier this month on me daily driver MGB.
It cranked over good but would not start unless I jumped the starter relay with the key turned on. The relay is similar to An early Ford V8. We used to call them solenoids.
When I twisted the key start ignition switch over to “start” it was dropping the power to the coil.
I ran a jumper wire from a live source to the coil. It started right away.
So I changed the ignition switch and it now stars the first turn. Old car.
Aarongriffey is offline   Reply With Quote
