Old 08-23-2020, 10:24 AM   #1
Clem Clement
Clem Clement's Avatar
Default suspension squawk
My fully restored 40Merc suspension squawks . It has new rebuilt original shocks and shackles. Also the metal sheaths over the springs. It has the center springs lubing fillings.
what next?
Clem Clement is offline   Reply With Quote
Old 08-23-2020, 12:55 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: suspension squawk
Did you grease between the leaves BEFORE putting the covers on??
Paul in CT
Old 08-23-2020, 02:17 PM   #3
Clem Clement
I did not do the build. I can see a little grease squeezing's out of the grease
fitting
Old 08-23-2020, 04:03 PM   #4
oldford2
oldford2's Avatar
If the tin covers were stapled on as original you can forget ever getting grease in between the leaves. Covers were not one of Henry's best ideas but a lot of 40's/50's cars had them. . Best bet is to remove them (not easy) and try spraying lube between the leaves. In the 50's I worked at a gas station lubing cars and we sprayed squeaky springs with a mix of kerosene and waste oil. Would last a 1000 miles. JMHO
John
oldford2 is offline   Reply With Quote
Old 08-23-2020, 05:23 PM   #5
Clem Clement
Thanks oldford2 Supposedly I can pump 140 wt thru the center fittings.
I lived in Hawaii in the 6's i saw lots of old cars with bad upholstery. Upon questioning they say Heh dakind Bruder dis is Hawaiian undercoat, Meaning spraying used oil underneath the entire car and they rat raced in the volcanic dust to hold the oil in place.
Old 08-23-2020, 06:48 PM   #6
oldford2
oldford2's Avatar
John
If they are original you will not be able to pump anything thru. But try it.
John
Old 08-23-2020, 09:27 PM   #7
JSeery
JSeery's Avatar
You should not be putting grease in between the spring leaves! Ford used a special lubricant for this and it is not grease. You can make up a mixture, but the easiest way to go is SlipPlate. I believe it also comes in tubes.
I don't have the lubrication charts for the later models, but before the addition of the fitting in the center bolt Ford recommended spraying the springs with Graphite Prenetrating Oil, L in the 32-35 diagram. After the fitting was used the correct lubricate was Ford M-4628, K in the 41 diagram
File Type: jpg 80456-1243873826-87b52943dba1107177607e08788bf1a2x.jpg (90.3 KB, 14 views)
File Type: jpg EAA7E4EB-EB6C-493E-902F-4C301850BC0E.jpg (51.5 KB, 9 views)
Old 08-23-2020, 09:57 PM   #8
JSeery
JSeery's Avatar
what next?
Clem, do you happen to remember this thread?
https://www.fordbarn.com/forum/showt...ight=slipPlate
Old 08-27-2020, 02:10 AM   #9
Clem Clement
I didn't. Thanks very much. I have been off the car work most of the summer. Still very tired and slow from my heart procedure. Thanks for helping me
Old 08-27-2020, 09:32 AM   #10
1ton
Back in my younger days when me and the wife were still active we had an old box spring that made god awful squeaks. Though lubrication was never an issue we had to retire that old thing because the kids were getting wise to what we were doing.
1ton is offline   Reply With Quote
Old 08-27-2020, 12:25 PM   #11
JSeery
JSeery's Avatar
The only really good solution is one you will not like. Remove the springs and covers and clean the spring leaves and start over. You can also try driving a wedge between each leaf and spraying them. None of this is simple or easy or fast.
Old 08-27-2020, 03:40 PM   #12
flatford8
flatford8's Avatar
This gave me a good chuckle!!.... Thanks!..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 08-27-2020, 04:49 PM   #13
drolston
drolston's Avatar
The squeak in the front end of my '41 was a dry shock. Maybe check your rebuilt units to be sure the seals are holding up.
Old 08-27-2020, 09:53 PM   #14
Clem Clement
I have used Slip plate on my 39 truck. A great help. I have to check the spring center bolt I think they may be too big for the lube to pass
Old 08-27-2020, 10:10 PM   #15
JSeery
JSeery's Avatar
I have used Slip plate on my 39 truck. A great help. I have to check the spring center bolt I think they man be too big for the lube to pass
The problem is if they have every been greased with something like axle grease it is very difficult to impossible to push it out with a proper lubricant. Even when working at it's best this system pumps the lubricant to the center of the springs. It's not really needed there, it's needed at the tips of the leaves. It is the tips that are squeaking.
Old 09-03-2020, 11:39 PM   #16
Clem Clement
Everything new to the 40 Merc. Very little sign of springs being lubed. One s
attachment had a star washer allowing the grease to squirt out. Noise is like dry surfaces contacting.
