Old 08-08-2020, 07:57 PM   #1
Bill Goddard
Bill Goddard's Avatar
Default Shifting problem with all new gear box parts
Some time ago Tom Endy posted that the repo shifting forks are questionable. I don't have ready access to old parts. Could someone tell me what is wrong with the repo parts so I can get them fixed? Thanks, Bill G
Bill Goddard is offline   Reply With Quote
Old 08-08-2020, 09:13 PM   #2
Jack Shaft
Default Re: Shifting problem with all new gear box parts
This is one area where parts interchability doesn't exist.Transmission assemblers at the Rouge had a box of sliding gears to 'fit' up an assembly, they would match up the best set of sliders and cluster gear.
Jack Shaft is offline   Reply With Quote
Old 08-08-2020, 10:35 PM   #3
Tom Endy
Tom Endy's Avatar
The repo forks that I have seen have the slots too narrow for the ball on the end of the repo shift lever to fit into.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-09-2020, 11:47 AM   #4
Bill Goddard
Thanks Tom and Jack. I will look into the ball/slot fit. Bill G
Old 08-09-2020, 04:39 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
You haven’t detailed “shifting problem”. You’ll get more ideas, if the problem was described.
Old 08-10-2020, 05:03 PM   #6
Bill Goddard
Problem was shifting from 1st to 2nd across the middle and occasional lockup at intersections. Poeple don't like old cars that hols up traffic.
Looked at alignment of forks on the shifting shafts and it is obvious forks don't line up side to side when in neutral. I will have to alter one or both.
Old 08-10-2020, 05:24 PM   #7
Tom Endy
Tom Endy's Avatar
Tower forks can become bent and cause shifting problems. it is often difficult to tell they are bent. I made a jig to check them. See attached article.
Tom Endy
