Old 08-06-2020, 07:05 PM   #1
Sheldon Paulger
Default Engine Knock at 2000 RPM
I had my 1930 model A engine rebuilt about 1200 miles ago. It was rebored, babbitt removed and shell bearings installed. I could hear a light knock from the beginning. The engine re-builder claimed all was normal.
Last winter, he agree to re-inspect the engine if I removed it from the frame. He dismantled it and while he had it apart, I had a Synders touring camshaft install and a Snyders 6:1 high compression head installed. The re-builder claimed he could find nothing out of order with his rebuild.
The engine seems to sound normal at low RPM but rattles as 2000 RPM is reached.
Read a couple threads talking about pistons hitting the head or the head gasket if it protrudes into the bore.
Any other ideas? Any way to check pistons hotting head or gasket without removing the head.
Sheldon Paulger is offline   Reply With Quote
Old 08-06-2020, 11:20 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Engine Knock at 2000 RPM
Are you positive it is an internal engine noise and not transmitting peripherally?
Old 08-07-2020, 12:32 AM   #3
fredski53
fredski53's Avatar
Odd, I had my engine rebuilt with inserts and it is making a similar noise! I have H/C head and electronic ignition. Builder claims too much advance. I've changed distributor back to points but knock still there. I've given up! Just drive it, and when it breaks, then I'll know what to fix!
fredski53 is offline   Reply With Quote
Old 08-07-2020, 07:59 AM   #4
old31
I have a Snyders 6.1 head, babbits and drive at 2,300 rpms and no noise.
Old 08-08-2020, 09:27 AM   #5
Licensed to kill
Licensed to kill's Avatar
Pull the plugs and look at the top of the pistons with a bore scope. If they are touching there should be a mark left on the piston.
Licensed to kill is offline   Reply With Quote
Old 08-08-2020, 02:26 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
So - - - is it a knock, or a rattle? Or did it evolve?
Old 08-21-2020, 05:59 PM   #7
Sheldon Paulger
It is knock that was there from day one of the overhaul (but fairly quiet). The knock seems to be getting louder at 2000 rpm and above.
Analysis of the oil shows high copper, iron, lead, and tin.
Old 08-21-2020, 06:56 PM   #8
Licensed to kill
Copper typically indicates a bearing, likely a main in this case. If it was a throw it would have "thrown" by now. A main can knock for quite awhile, maybe not as long on a 3 main model A as a modern engine but a lot longer than a rod. I would pull the pan and check all of them starting with the mains. Does the knock change with the throttle, IE better or worse when you give it gas or when you let off the gas?.
Old 08-21-2020, 08:22 PM   #9
Sheldon Paulger
Knock is only under load and 2000 rpm +. Can not hear knock sitting still and revving the engine with no load. Noise is there in all gears at 2000+.
Old 08-21-2020, 09:13 PM   #10
eagle
eagle's Avatar
Aluminum timing gear can make a metallic rattle although I think it most likely starts at lower rpm. Is a motor mount loose or front pulley touching? Take a prybar to lift engine while running.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 08-21-2020, 09:52 PM   #11
steve smith
Hard to hold on to that crowbar while putting on a load at 2000rpm going uphill
steve smith is offline   Reply With Quote
Old 08-21-2020, 10:20 PM   #12
Jack Shaft
The only way you get a copper reading on a model a is an engine with insert bearings and one or more of the bearings is coming apart
Jack Shaft is offline   Reply With Quote
Old 08-21-2020, 10:22 PM   #13
Jack Shaft
thats why I like high speed babbit..no thin liner of babbit ...nope,its all babbit..
Old 08-22-2020, 08:39 AM   #14
Kurt in NJ
Kurt in NJ's Avatar
Will the noise change if you retard the spark ?
Old 08-22-2020, 10:27 AM   #15
Sheldon Paulger
I will double check that today, but pretty sure I have done that with no change---will let you know.
Old 08-22-2020, 12:46 PM   #16
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
If I am reading the #1 post correctly, the knock has been in the engine since it was first rebuilt. Then upon a disassembly and inspection, a high compression head was installed. Since the knock has been there since the rebuilt engine was first completed, I think I would rule out piston interference.
As for the high copper, lead, and tin, ...these are items found in bronze, -and if the thrust bearing on the main was made from Bronze and then clearanced too tightly, this could be the source of those high levels in the oil.
Without being able to check clearances with micrometers and indicators, anything we say will just be speculation. Maybe it is one or more bent connecting rods, maybe tappet to bore clearances are excessive, maybe the line-boring operation bedded the crankshaft outside of being truly parallel with the cylinder case or even straight in the centerline.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-22-2020, 04:00 PM   #17
Jack Shaft
Trace values of a substance,like the copper component of bronze wont register as a 'hard value' on the spectrometer. Generally a copper 'warning' is from the bearing shell once the babbit is gone.Bronze wear will show as bronze.
Oil samples require rigorous attention to sample collection method as well as a baseline of samples to compare to.
Old 08-22-2020, 06:33 PM   #18
M2M
M2M's Avatar
Sorry to hear this has happened to you. Did the engine rebuilder ever hear this rattle at 2000 rpm? If no, why not? If yes, what did he say?
M2M is offline   Reply With Quote
Old 08-22-2020, 06:59 PM   #19
M2M
M2M's Avatar
Good post. Could be bad workmanship or a bad part. Being that the engine rebuilder has already taken it apart and checked it for problems (or so we think) it's hard to know where to go next in this situation. Start from scratch and have someone else rebuild the engine again?
