Old 08-06-2020, 05:08 PM   #1
M2M
M2M's Avatar
Thumbs up Best in class head
M2M is offline   Reply With Quote
Old 08-06-2020, 05:13 PM   #2
Jack Shaft
Default Re: Best in class head
Jack Shaft is offline   Reply With Quote
Old 08-06-2020, 05:15 PM   #3
Dodge
There was this girl in High School.......
Dodge is offline   Reply With Quote
Old 08-06-2020, 06:14 PM   #4
johnneilson
I remember her too.............
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 08-06-2020, 07:06 PM   #5
Jack Shaft
School? Olongapo...
Old 08-06-2020, 07:09 PM   #6
copgib
copgib's Avatar
Now that is a ex-Navy man talking, Olongapo.
copgib is offline   Reply With Quote
Old 08-06-2020, 07:12 PM   #7
fast150
fast150's Avatar
I spent some time in Olongapo. Crossed that bridge many times.
fast150 is offline   Reply With Quote
Old 08-06-2020, 07:19 PM   #8
Jack Shaft
Old 08-06-2020, 08:11 PM   #9
M2M
M2M's Avatar
I'd take the Super Power over the Winfield any day of the week !
Old 08-06-2020, 08:36 PM   #10
Jack Shaft
Riccardo design is good..Winfield red 7 to 1,Simmons 5.5 to 1..
Old 08-07-2020, 03:13 AM   #11
M2M
M2M's Avatar
7 to 1 So if you stick this head on a bone stock 40hp engine, how much of a boost in hp would you get?
Old 08-07-2020, 07:54 AM   #12
old31
Who ya, except the one I remember was "best in school" not class. OH YA
Yep, still smiling.
Old 08-07-2020, 07:55 AM   #13
old31
Jack, everyone knows that when you paint it that color you instantly gain 10HP!
Old 08-07-2020, 08:35 AM   #14
updraught
updraught's Avatar
What does the other side look like then?
updraught is offline   Reply With Quote
Old 08-07-2020, 10:25 AM   #15
Jack Shaft
Boosting power and efficiency is a sum of all parts,the head alone will help but to gain maximum return matching carburetor flow rate to engine flow rate,increasing cam lift and duration,providing engine rpm controlled timing and increasing exhaust flow along with the compression increase from the head yields results..and yes,RED is a proven secret of speed,it goes faster,runs cooler and gets more chicks..
Old 08-07-2020, 10:39 AM   #16
johnneilson
I thought it was 10 MPH!!
Just an observation, all the heads raising compression will give some increase in power. There are many factors to consider, carby, manifold etc. The stock carb is like drinking a milkshake thru a small straw, you get the idea.
But, like anything, the results will be only as good as the work put into it.
By this I mean tuning, optimized timing, fuel curve close and of course the motor must be in good repair BEFORE you start.
J
Old 08-07-2020, 10:51 AM   #17
Jim Brierley
Adding compression and a bigger carb are the quickest and easiest ways to more power. Hard to beat a Winfield, unless it is a BRIERLEY head. I'd post a pic but posting here is too complicated for my old brain. Facebook is much easier. A Stromberg 81 is much better than a stock carb, a 97 is even better.
Jim Brierley is offline   Reply With Quote
Old 08-07-2020, 10:54 AM   #18
Jack Shaft
There are benefits of raising efficiency of your 200 cubic inch L head engine..Your engine will run cooler,fuel economy will increase and the power is pleasant. Bear in mind,as John said,you cant build a house with a poor foundation and expect it to last..
Old 08-07-2020, 11:38 AM   #19
johnneilson
Jim,
There are pics all over the web of your Cyl Head.
For the un-initiated, look at where the spark plugs are...................J
Pic liberated from HAMB Banger meet, over there....
Old 08-07-2020, 12:56 PM   #20
kenparker
kenparker's Avatar
BRIERLY head. didnt know there wa one. Tell me more or where on facebook do I look. ken
kenparker is offline   Reply With Quote
