#1 |
I have a question for the flathead gurue's , I have a 8ba motor with made in Canada on the heads , has aluminum intake 2 bbl. with 4 bolts, CC 9425 on the manifold, pulled 1 head, 4 inch stroke bored 3.250 with the pistons marked .040 , the motor turns over freely , has been converted to 12 volt coil and alternator . Has 3 speed trans attached , column shift . Valves all look good and marked ford script , see no visable cracks . What is this and how many cubic inches, and value , was going to use in my 40 ford but changed directions.
#2 |
I think you are supposed to put this in the swap meet section. With a standard bore it would be 255 cu in. Now maybe 265-270? Anyhow you should list it in the swap meet with some photos. It will sell.
#3 |
260 cubes, interesting intake. However without a good block the value is questionable. Sometimes known as "A pig in a Poke"
#4 |
The 4 inch crank has value, again if its good. Always a crap shoot with flatheads.
Making the simple complicated for over 30 years. |
#5 |
