Old 07-28-2020, 12:10 PM   #1
farmerdick
farmerdick's Avatar
Default Oil pressure gauge
Can a threaded oil pressure gauge be screwed into one of the
drivers side rear engine ports and get an accurate oil
Pressure reading? Richard
farmerdick is offline   Reply With Quote
Old 07-28-2020, 12:24 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Oil pressure gauge
Yes, as accurate as the gauge will read.
Old 07-28-2020, 01:14 PM   #3
marko39
If you're using a oil filter, gauge can be installed at filter inlet as it is much more acessable. Mark
marko39 is offline   Reply With Quote
Old 07-28-2020, 02:03 PM   #4
farmerdick
farmerdick's Avatar
Thank you very much.
