07-27-2020, 12:14 PM | #1 |
There must be a better way
I am in the process of installing new distributor wiring and things are not going well! There must be a simpler way. When i attempt to connect the spark plug wires to the terminal plate and then rotate the plate notch to align with the distributor notch, the wires either pull out or resist any turning movement. I have tried different wire arrangements to no avail. I am using standard 7mm wires.
Thanks |
07-27-2020, 12:23 PM | #2 |
Re: There must be a better way
Tom, We've all been there and couldn't agree more. Keep at it, that insulation is tough, but will bend for you if you insist!
Alan |
07-27-2020, 12:29 PM | #3 |
First using crimp on connectors is the hard way of doing it...they will not fit very good in the caps.
Solder connectors will make life easier for you since the cable will rotate and stick out less. Just my 2c. |
07-27-2020, 12:38 PM | #4 |
It's not an easy task, I found that starting with the two wires to the bottom of the cap first, then the two at the top works best as it relates to the notch in the cap!!! You can bend and fit each wire to the cap and see just how to route it around the center post of the cover and where it best exits the cover hole. Then I found that IF you orient the wires, the two shortest to the front (IF you are looking at the engine from the side of the car) and the two longest behind those, then feed them into the spark plug tube!!! A bend Awl helps a lot once you start feeding the wires into the tube. ALSO make sure and lay out ALL the rubber o-ring, gaskets and rubber boot as not to "FORGET" any of the parts and have to pull it back apart to fix what you left off!!!! Ask how I know about that!!! I hope it's at least clear as mud???
07-28-2020, 11:47 AM | #5 |
Tom-MI
How did you fair? Get any good info and find it any easier??? |
07-28-2020, 06:52 PM | #6 |
I worked on it off and on yesterday. Very frustrating. I tried to follow your instructions but I need to read it more carefully. One suggestion of soldering the wires sounds interesting but I can't see how the wire would be held better than a conventional clip. I can't imagine how these wiring looms could be assembled fast enough to support a moving production line. Tom |
07-28-2020, 07:07 PM | #7 |
I would use a different brand of wire.
07-28-2020, 08:15 PM | #8 |
These terminals are what I would recommend for ease of use in this situation.
https://brillman.com/product/old-sty...coil-terminal/
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
07-29-2020, 06:32 AM | #9 |
Tom you are doing a helmet dist. The only thing worse is the Rabbit ear cap that was used on the 2 bolt dist. I don’t see how you can possibly get the wires to stay in using the crimped ends .
07-29-2020, 07:09 AM | #10 | |
07-29-2020, 09:40 AM | #11 |
I have wondered the same thing myself. They must have had enough people assembling the caps, wires, and loom units in a different part of the factory so that the assemblies were available at the right time on the assembly line.
07-31-2020, 05:53 PM | #12 |
A timely thread as I'll be on the same task soon.
My "new" 11+ year old, wire set from C&G has terminal similar ends to those pictured. According to the directions, they go on the plugs. The other end is a soldered terminal that is shorter and likely more manageable for my helmet caps. Perhaps the newer reproduction coil/distributor wire sets differ from my set. |
07-31-2020, 09:01 PM | #13 |
The terminals on the ends of your high tension wires are not correct as they stick out way too far. The original terminals push right into the cap and dont show above the cap. Once you have corrected this problem then the wires will have more room to bend inside the outer cap. Regards, Kevin.
07-31-2020, 10:56 PM | #14 |
The Brillman solder on terminals are much shorter & let the cable bend right in by the terminal plate.
Phil |
