Old 07-20-2020, 07:16 PM   #1
stewgee
stewgee's Avatar
Default Pressure plate adjustment
Looking for a little advice on how to adjust the fingers of the pressure plate in the car. Clutch and pressure plate are new. Well almost new. I thought I adjusted the pp fingers when I installed it but apparently I didn't. Instead of the proper 5/8" per Les Andrew's mine are around 3/8". Obviously they need to be adjusted . Just not sure how to do it.
stewgee is offline   Reply With Quote
Old 07-20-2020, 07:26 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Pressure plate adjustment
I made that mistake as well. Not horrible to adjust in the car just slow going. I made up a tool to gauge and set the finger depth to 11/16". I managed to get each finger adjusted to +/-0.004" which is probably as good as can be with the transmission installed. In my case it did solve my clutch chatter.
I'll try to grab a picture of my tool tomorrow. It's very ugly but functional.
ryanheacox is offline   Reply With Quote
Old 07-20-2020, 07:28 PM   #3
stewgee
stewgee's Avatar
Thanks I appreciate it
Old 07-20-2020, 07:49 PM   #4
Patrick L.
Patrick L.'s Avatar
Is there a problem ?
Can the free-play be set ?
Where does the clutch engage ?
Old 07-20-2020, 09:00 PM   #5
stewgee
stewgee's Avatar
Patrick L there is a problem or I wouldn't be asking for help. I cannot get the clutch to engage at the 1 inch spec. My inquiry is for help with adjusting the pressure plate fingers with it installed in the car
Old 07-20-2020, 09:35 PM   #6
Tom Endy
Tom Endy's Avatar
Attached article is how it can be done. I prefer to make the adjustment with the flywheel laying on a work bench. A second choice is with the flywheel attached to the engine and with the transmission removed. A friend has successfully made the adjustment through the bell housing window with the transmission attached, but I would never attempt it.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 07-21-2020, 05:27 AM   #7
Patrick L.
Patrick L.'s Avatar
The pedal free-play should be about 1.5", but, that is not where the clutch should engage/disengage. That should happen when the pedal is about 3-5" from the floorboard. [ about half way from floor and end of free-play position, middle of pedal movement under pressure plate spring tension]
Changing the height of the pressure plate fingers is best done on the work bench.
Getting all the fingers to touch at the same time while the clutch is in the vehicle isn't too hard, but, changing the setting of all the finger heights is. To do that I take it out and set it on the bench.
Old 07-21-2020, 05:55 PM   #8
stewgee
stewgee's Avatar
Got it....finally managed to adjust it like you say. Thanks
Old 07-23-2020, 08:34 AM   #9
ryanheacox
ryanheacox's Avatar
Seems I'm a bit late but this is the tool I made up to adjust the fingers through the inspection cover. My fingers were all too high like yours and they were all varied +/-1/16". The surface with the writing on it goes against the pressure plate and the finger contacts the pressure plate finger. I adjusted each so that a .002 feeler gauge would just drag. Smoothed my clutch right out. I would have made the part that goes against the pressure plate longer but that was the length that would fit through the inspection cover.
Old 07-23-2020, 09:42 AM   #10
katy
katy's Avatar
Ryan, how about some measurements of your gauge?
Old 07-23-2020, 11:01 AM   #11
ryanheacox
ryanheacox's Avatar
Sure thing, I can get some measurements this afternoon.
Old 07-24-2020, 11:14 AM   #12
stewgee
stewgee's Avatar
If the clutch fingers aer too close what happens? Thanks for sharing your gage Ryan. Interesting
Old 07-24-2020, 01:18 PM   #13
Patrick L.
Patrick L.'s Avatar
The height of the fingers determines where engagement/disengagement takes place.
Old 07-24-2020, 08:56 PM   #14
stewgee
stewgee's Avatar
Bear with me here Patrick. I'm a newbie on the A. I've adjusted the linkage to where the clutch engages at about half way. Trans shifts fine. However the fingers are still at about 3/8 inch gap from the disc not 5/8 as recommended. Guess I'm trying to tie the 2 together to make sense
Old 07-25-2020, 05:39 AM   #15
Patrick L.
Patrick L.'s Avatar
How much free-play do you have ?
How much travel in the pedal before the clutch engages ?
If you have about 1.5" free-play, and, the clutch engages about 3-5" from the floorboard, and, the transmitter shifts good, then you're good.
Old 07-26-2020, 05:07 PM   #16
stewgee
stewgee's Avatar
Got it and thanks for the help
