Old 07-18-2020, 11:44 AM   #1
shoe box Jack
Default power valve
I'm replacing the pv. in the 94 carb. I have the pv. fairly tight and it still seeps a little, how tight should it be??. thanks for any info. Jack.
shoe box Jack is offline   Reply With Quote
Old 07-18-2020, 12:06 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: power valve
Good luck. It seems many of the rebuilding PVs have too much of an angle at the base of the threads preventing the gasket from sealing also the soft gasket supplied often leaks. Charlie Schwendler may have a good gasket.
Old 07-18-2020, 12:26 PM   #3
tubman
tubman's Avatar
You probably have a later power valve. They look the same, but the sealing area is slightly different from the proper early valves and they will leak. As long as you're getting a gasket from "Charlie ny". you might as well get a power valve too.
Old 07-18-2020, 12:41 PM   #4
Jockeyshift41
Jockeyshift41's Avatar
You want one like the one on the right with no radius at bottom
File Type: jpg 5D3D159D-CF9D-423B-9C8C-2B6BFBEA464A.jpg (25.9 KB, 127 views)
Al
Jockeyshift41 is offline   Reply With Quote
Old 07-18-2020, 03:11 PM   #5
shoe box Jack
thanks guys for the come back. Tubman how do I get in touch with charlie ny. Thanks again Jack.
Old 07-18-2020, 03:34 PM   #6
petehoovie
petehoovie's Avatar
[email protected]
Old 07-19-2020, 08:48 AM   #7
shoe box Jack
Thanks Petehoovie. Jack.
Old 07-19-2020, 09:32 AM   #8
tubman
tubman's Avatar
That's a great comparison picture, Al. Everyone with a Holley carb should save a copy.
Old 07-19-2020, 11:43 AM   #9
scicala
scicala's Avatar
Also, Charlie ny prefers the power valves that have four small side holes instead of the two large square windows.
Sal
Old 07-19-2020, 02:31 PM   #10
Bored&Stroked
Bored&Stroked's Avatar
I believe the correct Power Valves and quality carb kits may also be purchased from Daytona Auto Parts:
https://daytonaparts.com/
Old 07-19-2020, 08:22 PM   #11
Garagekulture13
Garagekulture13's Avatar
I just went through troubles with my 94. I sent my carb to Charlie. Got it back last week and the car runs great.
Sent from my SM-N950U using Tapatalk
Garagekulture13 is offline   Reply With Quote
Old 07-20-2020, 11:55 AM   #12
Tom's36coupe
Tom's36coupe's Avatar
Charlie did my two 94's, work great! he is the man
Tom's36coupe is offline   Reply With Quote
