Old 07-15-2020, 07:17 PM   #1
stewgee
stewgee's Avatar
Default Shifter spring compressor
Has anyone in the Barn ever had the good fortune of purchasing the shifter spring compressor tool from Ecklers? Sounds good and looks good in the catalog but it is a real chore to use without taking your head off. I finally got the old spring out without killing myself but I have had no luck compressing the new spring sufficiently enough to get the clip on. Any suggestions will be appreciated
stewgee is offline   Reply With Quote
Old 07-15-2020, 07:55 PM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Shifter spring compressor
While wearing a pair of gloves and wearing safety glasses place the spring in a bench vice at the corner with part of it out of the vice and compress the spring all the way down. It will be difficult at first because the spring will want to squirrel around. Once it is all the way down put a loop of safety wire through the spring and twist it tight. Loosen the vice slightly and rotate the spring and put another loop of safety wire through the spring. Do this three times so that the three wire loops are even. Remove the spring from the vice and drop it over the bottom end of the shift lever. Carefully insert the spring retainer and cut the safety wire and with long nose plyers pull the broken pieces of wire out.
I did this a number of times many years ago until I acquired a spring tool.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 07-15-2020, 08:11 PM   #3
chrs1961815
chrs1961815's Avatar
I never had luck with the safety wire trick. With the tool it is tricky, though two people would probably make it a lot easier as I did it by myself. You can take the spring out by pulling the retainer out and having the housing angled towards the workbench and it will just bounce inside. Installation you need the tool.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-15-2020, 08:29 PM   #4
Benson
PM Sent to 20500
Benson is offline   Reply With Quote
Old 07-15-2020, 08:29 PM   #5
SSsssteamer
SSsssteamer's Avatar
For years I have been using a valve spring compressor meant for overhead valves. It is tedious work but I have always prevailed getting the shifter spring and it's keeper back in.
Sound like from above posts, that I have it easier than those using the shifter spring compressor that was meant to to do the job.
SSsssteamer is offline   Reply With Quote
Old 07-15-2020, 08:41 PM   #6
stewgee
stewgee's Avatar
Installing with the compression tool is almost impossible. At least from what I've seen
Old 07-15-2020, 08:51 PM   #7
Bill G
Bill G's Avatar
I used the compression tool from Mikes. That was one of those things that turned out to be a non-event. It went right in. I had an old workbench that I drilled a hole in the top so that I could put the shift tower cover with the shifter upside down and held secure so I could concentrate on setting the spring without having to worry about the whole thing moving around.
Bill G is offline   Reply With Quote
Old 07-15-2020, 08:53 PM   #8
Roger V
Roger V's Avatar
I've done Tom's method or somewhat like it but with a short dowel rod inside. I'm guessing but think it may have been 1/2" diameter and 2 3/4" long. This way you can rotate the spring safely with the dowel rod tightly clamped(spring will be almost fully compressed). Then thread the wire, tighten, move 120 degrees until you have three wires.
Roger V is offline   Reply With Quote
Old 07-15-2020, 09:10 PM   #9
Gary WA
Gary WA's Avatar
Berts and Brattons have them Berts is different than this style
www.whidbeymodelaclub.com
Old 07-16-2020, 08:42 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
With the spring retainer in place, I found that I could screw the spring into the gear shift using Visegrip pliers and grease. The last spring coil would not go past the retainer, so I cut it off. This gearshift has been in use since 2016 and it works great. I conclude that the OEM spring is excessive.
Bob Bidonde
Old 07-16-2020, 09:40 AM   #11
stewgee
stewgee's Avatar
This method sounds promising. However it looks to me like the dowel would need to be a bit larger than 1/2 inch. Thanks for the idea Roger. And thanks everyone else for your suggestions.
Old 07-16-2020, 01:54 PM   #12
Brentwood Bob
Double up the wire. It's cheap insurance.
Brentwood Bob is offline   Reply With Quote
Old 07-16-2020, 02:05 PM   #13
ryanheacox
ryanheacox's Avatar
You can also use a piece of copper pipe (can't remember the size, maybe 1") to put over the spring while you compress it in the vice and then use the safety wire. Adds a factor of safety.
ryanheacox is offline   Reply With Quote
Old 07-16-2020, 07:05 PM   #14
stewgee
stewgee's Avatar
Roger V you were spot on with the measurements of the dowel. Anything bigger than 1/2 inch would have been to big and would have made it difficult to feed the safety wire thru the spring. Anyway it worked rather well and that part of the rebuild is done. Thanks
Old 07-16-2020, 07:12 PM   #15
stewgee
stewgee's Avatar
Didn't have a wooden dowel but a 2 3/4 inch by 1/2" metal conduit worked just as well
Old 07-17-2020, 07:30 AM   #16
stewgee
stewgee's Avatar
Not a bad idea
Old 07-17-2020, 07:31 AM   #17
stewgee
stewgee's Avatar
Not a bad idea for sure.
Old 07-20-2020, 04:29 PM   #18
dmaxweb
dmaxweb's Avatar
Just working on the same thing myself. I was concerned about the spring popping out of the vise jaws. So, I used a piece of all thread, two fender washers, and two nuts compressed to 2-3/4".
Now, what size safety should be used and can the wire be twisted with a common pliers or do I need a safety wire pliers to get it tight?
dmaxweb is offline   Reply With Quote
Old 07-20-2020, 06:41 PM   #19
stewgee
stewgee's Avatar
I do like that idea. I used standard black safety wire and twisted it with lineman electrician pliers. They are wide and worked well. Just be sure and put 3 wires equally spaced. The toughest part is getting all the wire out after you install the spring. Good luck
Old 07-21-2020, 09:51 AM   #20
sofield
I like your idea as the spring is totally contained by the rod and washers, expanded on your idea I would use a washer just a little larger then the OD of the spring and cut three notches equal distance around each washer. This would allow you to not have to remove the washer to install the last two springs.
Sofield
sofield is offline   Reply With Quote
