Old 07-04-2020, 02:33 PM   #1
FrankWest
FrankWest's Avatar
Default supplier of 1933-34 Ford Windshield Rubber
looking to replace my existing one that split apart.
FrankWest is offline   Reply With Quote
Old 07-05-2020, 11:20 AM   #2
95476
95476's Avatar
Default Re: supplier of 1933-34 Ford Windshield Rubber
I have used Carpenter and Drake. The last two I did came with the frame from Trautwein.
The hardest parts is removing all the old rubber from the frame.
95476 is offline   Reply With Quote
Old 07-05-2020, 12:27 PM   #3
Lawson Cox
Lawson Cox's Avatar
I have always liked Carpenter's rubber the best. My 2¢.
Old 07-05-2020, 01:47 PM   #4
FrankWest
FrankWest's Avatar
I tried to superglue the separated area and it held for about 2 hours. I guess the tension was too much for the glue. Do you think jb weld would hold better than superglue. It is hard to glue to rubber because as it stretches it compromises the bond.
I will buy from carpenters, thanks fot the info.
Old 07-05-2020, 02:08 PM   #5
Lawson Cox
Lawson Cox's Avatar
I have never tried super glue on rubber so I can't comment on that. Good luck
Old 07-05-2020, 02:22 PM   #6
Merc Cruzer
Merc Cruzer's Avatar
Steele Rubber Products
800-544-8665
www.steelerubber.com
Merc Cruzer is offline   Reply With Quote
Old 07-07-2020, 12:33 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
I have no experience with installing '34 WS gaskets, but thought I would mention that I had my best luck using windshield rubber gaskets from Bob Drake on my '35 Fords. He has the '35-'36 WS gaskets with corners molded plus the molded rubber seems to be softer, and more pliable than any other manufacturers gaskets that i have tried.
John
Old 07-07-2020, 01:05 PM   #8
fourfords
fourfords's Avatar
My '33 rubber gasket was a one piece if I recall. No cement or glue of any kind. I was patient with working it into the frame, fit perfect. Still in perfect condition.
fourfords is offline   Reply With Quote
Old 07-12-2020, 11:05 AM   #9
FrankWest
FrankWest's Avatar
the rubber that tore apart was purchased from Bob Drake. I am surprise because Dakes carries quality stuff..Maybe it was just from a bad batch.
Old 07-12-2020, 07:05 PM   #10
JM 35 Sedan
Who installed the rubber gasket that tore apart?
My first couple attempts at installing these rubber windshield gaskets did not go well. The first one I tried, I definitely DID NOT have all the old rubber from the previous gasket completely cleaned out of the groove in frame. Then I was NOT using the best tool I could have chosen to push the rubber into the groove. Then I chose the wrong lube to use trying to make the rubber go in place, then finally I determined that I was not putting the right part of the gasket into the channel first. After much frustration, and ruining one gasket I nailed the proper installation procedure and everything worked and went together perfectly.
Unfortunately, I suspect that most folks complaining of having problems, and blaming the manufacturer's product, are actually experiencing user error.
John
Old 07-13-2020, 08:35 AM   #11
TJ
TJ's Avatar
How old is the rubber that split apart?
Old 07-14-2020, 04:26 AM   #12
FrankWest
FrankWest's Avatar
2 years old
Old 07-14-2020, 04:31 AM   #13
FrankWest
FrankWest's Avatar
I installed it..
I totally cleaner out the channel, checked every inch. I did not break during the installation but only after a year or so in place. I noticed the separation along the left edge!
Old 07-14-2020, 08:59 AM   #14
oldford2
oldford2's Avatar
Steele's rubber parts. Quality rubber and I believe they supply some vendors.
John
oldford2 is offline   Reply With Quote
Old 07-14-2020, 09:46 AM   #15
TJ
TJ's Avatar
Did you use any chemical lubricants during the installation?
Old 07-14-2020, 11:28 AM   #16
FrankWest
FrankWest's Avatar
silicon spray applied into frame
Old 07-14-2020, 11:32 AM   #17
FrankWest
FrankWest's Avatar
This defect was not because of the installation, that would have given a tearing during the process. everything assembled properly. The rubber gasket was in place perfectly for 1 to 2 years. Then one day when I was driving I notice the lower left portion flapping around and realized that it was disconnected from the bottom part of the gasket.
My car is not left out in the sun but is always garaged, I do almost no driving...I have to start using the car , otherwise all I have is a stationary model.
Old 07-16-2020, 03:42 PM   #18
alchemy
alchemy's Avatar
I've got 14 years on a Dennis Carpenter seal in my 32 sedan. Still looks good. I had first tried a Vintique but the glued corners broke before I could even get the thing stretched all the way around.
Two weeks ago I installed a Drake seal on my brother's 32 coupe. It is tight, but it went into place as well with no breakage.
alchemy is offline   Reply With Quote
Old 07-16-2020, 03:46 PM   #19
35fordtn
35fordtn's Avatar
I have had good results with Drake and Carpenter and have used both and stock both.. Steele gets theirs from Carpenter I believe if I remember right. Vintique, I had bad luck with. I plan to use a Carpenter seal on my 36 as the drake one on it (5 years old) is starting to crack at a corner.
35fordtn is offline   Reply With Quote
Old 01-03-2023, 05:01 PM   #20
highbeams
highbeams's Avatar
https://www.rubbertherightway.com/19...09171-prd1.htm
Just found this site. Haven't used them. FYI. Thank you.
(19.95 for a '33 closed car.)
highbeams is offline   Reply With Quote
