Old 07-01-2020, 04:28 AM   #1
wkuehnis
wkuehnis's Avatar
Default Signal for a electronic speedometer
Hi,
I am building a A Speedster.
I use all Gauges with the same design .
Now I need the signal for the electronic speedometer.
Does anymode have a solution?
I think, the only way is the position at the torqueTube, where the original cable driven speedometer is connected.
Here I can get the signal from a rotating cable or Pin and transfee it to a electronic signal.
Does anybody has a drawing of such a solution?
Thanks for help
Willi
wkuehnis is offline   Reply With Quote
Old 07-01-2020, 05:01 AM   #2
rally 1
Default Re: Signal for a electronic speedometer
Speedhut Gauges. has a speed sensor that screws directly onto the “turtle” and drives the electronic speedometer.
The speedo that they sell is calibraitable, and very slim body. Works great in the A dash panel.
Only available in 12v, neg ground
Been using them for years.
Ken
rally 1 is offline   Reply With Quote
Old 07-01-2020, 05:07 AM   #3
rally 1
Followup:
speedhut # G-SNDR-11
Listed as a GM/Chrysler style, mag pulse. $50.85
Old 07-01-2020, 11:39 AM   #4
wkuehnis
wkuehnis's Avatar
Great answer!
Thanks a lot
Willi
Willi
Old 07-01-2020, 12:33 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by rally 1 View Post
Speedhut Gauges.
Ken
Excellent choice!!
Speedhut has a GPS speedometer also if interested in that. I have a Speedhut 2" 4000 RPM tach.
File Type: jpg Screen Shot 2020-07-01 at 10.38.45 AM.jpg (12.6 KB, 4 views)
