Old 06-28-2020, 12:19 PM   #1
jake1955
Default 1955 Country Squire Speedometer
Trying to fix the speedometer in my '55 Country Squire. It is a Fordomatic transmission.
I've replaced the cable with a NOS version that is correct for the '55 Fordomatic. As soon as the car gets to over 10mph, the cable begin squeaking and the needle pushes all the way to the right. It finally stops when I slow down to a stop.
I've tried another speedometer purchased off Ebay, and connected it to the cable and setting it on the floor-- it does the same thing in both.
Any suggestions?
jake1955 is offline   Reply With Quote
Old 06-28-2020, 01:40 PM   #2
JSeery
JSeery's Avatar
Default Re: 1955 Country Squire Speedometer
Might also try asking on the later model section (late V8 54+)
Old 06-28-2020, 05:42 PM   #3
rotorwrench
rotorwrench's Avatar
The drag cup is catching on the rotating magnet. The bearings either need lube or replacement. It may be easier to replace the whole unit.
Old 08-23-2020, 07:23 AM   #4
jake1955
Thanks rotowrench, replaced the unit with an NOS one and everything is working great.
Old 08-23-2020, 07:29 AM   #5
joe 1950
joe 1950's Avatar
Jake1955 just want to say that’s a great looking country squire glad someone here could help you
joe 1950 is offline   Reply With Quote
