Old 06-22-2020, 09:12 AM   #1
txmike
Default Pop Out Switch
If I install a original pop out switch with my new modern set up (no points etc) will it work or should I go with modern ignition switch?
1929 Coupe......
tsk
txmike is offline   Reply With Quote
Old 06-22-2020, 11:19 AM   #2
Joop
Joop's Avatar
Default Re: Pop Out Switch
You got to use a modern switch with modern distributor.
Joop is offline   Reply With Quote
Old 06-22-2020, 01:30 PM   #3
shew01
shew01's Avatar
Are you sure? I have an original pop out switch installed in my car, and I have a modern distributor still in its shipping box. To me, it looks like modern or old, the distributor would connect the same way. I don’t see how the modern distributor would “know” what kind of switch would be in use. There is only one (armored cable) connection between the pop out switch and the distributor. What am I missing?
shew01 is offline   Reply With Quote
Old 06-22-2020, 01:39 PM   #4
Joop
Joop's Avatar
Yes I am sure as he is talking about a no point system (electronic?)
Old 06-22-2020, 02:34 PM   #5
Bob C
Which modern distributor do you have?
Old 06-22-2020, 03:56 PM   #6
shew01
shew01's Avatar
Sorry, I’m missed that somehow.
Old 06-22-2020, 04:01 PM   #7
shew01
shew01's Avatar
Old 06-22-2020, 05:09 PM   #8
Bob C
OK, I though you maybe had an FSI Zipper distributor.
Old 06-22-2020, 07:44 PM   #9
shew01
shew01's Avatar
So my modern distributor should work with a pop out switch?
Is the FSI Zipper electronic ignition?
Old 06-22-2020, 07:49 PM   #10
Bob C
Yes and Yes
