Old 06-17-2020, 04:14 PM   #1
FrankWest
FrankWest's Avatar
Default removing distrubutor shaft
Is there a way to remove the distributor shaft without messing up the timing? I am thinking of replacing my head gasket.
FrankWest is offline   Reply With Quote
Old 06-17-2020, 04:25 PM   #2
Ruth
Default Re: removing distrubutor shaft
The distributor and shaft will only go in one way so yes you can remove it without messing up the timing.
Ruth
Old 06-17-2020, 05:19 PM   #3
cas3
the slot in the shaft is off set, only fits one way Frank
Old 06-17-2020, 06:00 PM   #4
FrankWest
FrankWest's Avatar
Great...Thanks
Old 06-17-2020, 06:00 PM   #5
Bob from Northport
Bob from Northport's Avatar
Just don't move the crank shaft
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 06-17-2020, 06:29 PM   #6
J Franklin
J Franklin's Avatar
It won't mess anything up to turn the crankshaft since as the post above say it only goes back where it belongs. Most other cars maybe so.
Old 06-18-2020, 08:47 AM   #7
Purdy Swoft
Purdy Swoft's Avatar
Loosening the distributor cam screw and moving the distributor cam will get the engine out of time
Old 06-18-2020, 08:51 AM   #8
Will N
Will N's Avatar
IMHO, if you are up to tackling replacing a head gasket, the least of your worries should be disturbing the timing. So many people fret over the timing for no good reason. Resetting the timing is so simple a job compared to removing and replacing the cylinder head. But, yes, so long as you do not loosen the cam in the distributor, you won't change the timing. As others have said, it goes back in only one way because of the offset slot in the shaft.
Will N is offline   Reply With Quote
Old 06-18-2020, 12:20 PM   #9
cas3
Frank has a 33, i am not familiar with that dizzy, do they still use the same cam screw set up as the A ?
Old 06-18-2020, 12:52 PM   #10
ursus
Yes, same cam and screw arrangement on top and same shafts down below. The '33 would have the Model-B distributor cam.
ursus is offline   Reply With Quote
Old 06-18-2020, 12:58 PM   #11
Purdy Swoft
I believe that the model B distributor cam is the only one made today . The B distributor cam has a better profile and works good on the model A distributor
