#1 |
The previous owner installed a Nu-Rex timing indicator on the front of the engine, and he left me the vendor instructions. However, I don't have a 6 volt timing light.
Can anyone recommend a good 6 volt timing light? |
#2 |
Use a buzz box, a test light, or a continuity tester instead. Align the mark on the pulley to whatever the desired degree number on the indicator, and then the points should just break or open at that location.
#3 |
I have Pertronix 6v Ignition in my distributor and Nurex timing indicator and have used a 12v timing light for the past 12 yrs.I just have to reverse the leads for power.
#4 |
I use a battery operated timing light.
#5 | |
Just pay attention to the color of the battery leads. The red one goes to ground, if the car is wired to original positive ground. Then the black one goes to a power source; I use one of the brass wing nuts on the cover of the terminal box. My timing light uses inductive pickup (a small black end clamps around the ignition lead for plug #1). This is trickier to do with the original style bronze strips connecting from distributor body to spark plug. I slip a short piece of clear tubing over the bronze strip first, to insulate it from the induction pickup, then clamp over that. It works.
Jim Cannon Former MAFCA Technical Director ![]() "Have a Model A day!" |
#6 |
Bob from Northport Northport, Michigan |
#7 |
The timing pin works great on 6, 8 or 12V
#8 |
I would never buy a Snap-On timing light (or anything else electrical). I had one and it spent more time being repaired than in use. Great hand tools but their electronics SUCK.
Ruth "Sometimes you really DO need to read the whole thread" |
#9 | |
Not a good thing when you have a Pacemaker... ![]() |
#10 |
This battery powered timing light works quite well. Just slip an insulating sleeve over the number 1 bronze strap.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
#11 |
I have powered my 12V timing light with my 6V/12V battery charger... just select 12V and power it up.
