Old 06-15-2020, 11:35 AM   #1
old john
Default horn kit 1960 F100
Changing to power steering cant use horn with stock steering wheel and stock column. Adapter available ? Thanks John
old john is offline   Reply With Quote
Old 06-17-2020, 08:42 AM   #2
54vicky
54vicky's Avatar
Default Re: horn kit 1960 F100
wow with all that information you may be waiting awhile.there are a few blanks that need to be filled in.
54vicky is offline   Reply With Quote
Old 06-18-2020, 11:01 AM   #3
old john
1960 ford F100 with stock steering column and stock steering wheel installing power steering want to use stock wheel can not use stock wheel and horn ring to make horn work is there a kit to use a adaptor and horn kit Thanks John
Old 06-21-2020, 09:23 AM   #4
flathead 53
I Think you are concerned about the wire going through the steering shaft on the original column , check with mid fifty,s I have seen something about A column saver,
flathead 53 is offline   Reply With Quote
Old 06-21-2020, 11:39 AM   #5
dmsfrr
dmsfrr's Avatar
I'm assuming your question relates to the original steering box having the horn wire running thru the center of it... and now you're changing to a newer/different style power steering box without that feature. Is this correct???
I'm sure a solution has been found but I'm not familiar with it.
dmsfrr is offline   Reply With Quote
Old 06-21-2020, 12:45 PM   #6
old john
Thank You Flathead 53 and dmsfrr John
Old 06-22-2020, 03:57 PM   #7
flathead 53
Also ,Fat Man fabrications has a kit ,column saver kit ,part number 990044
