Old 06-07-2020, 05:17 PM   #1
53_mercLuke
Default 1953 Flathead acceleration issue again
Last week I posted I had acceleration issues on my 1901 yeapot carb. I moved the accelerator pump adjustment to the right from the middle hole and also found the diaphragm for the power vavle was shorter so I changed it out. Took it for a drive and ran awesome for the most part but my volt meter was pegged and it would spit and sputter when it was so I found the alternator was bad, had it rebuild and put on. Now its charging fine but the acceleration issue is back now. I didn't do anything to the carburetor from last week so I don't know what happened. Any ideas? I'm just getting frustrated and confused. Thanks
53_mercLuke is offline   Reply With Quote
Old 06-07-2020, 05:30 PM   #2
JSeery
JSeery's Avatar
Default Re: 1953 Flathead acceleration issue again
Multiple issues can be like that. Any electrical parts damaged by the alternator problem? The old standby is start with the condenser.
Old 06-07-2020, 06:10 PM   #3
A bones
A bones's Avatar
How is your tank?
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 06-07-2020, 06:22 PM   #4
53_mercLuke
Its good and I replaced the fuel filter last week. I'm getting fluid to the carb and in the bowl
Old 06-08-2020, 10:52 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Although you are getting fuel to the bowl, check the tightness of the glass bowl and the condition of the cork gasket.
Looseness or a cracked gasket can cause air to be sucked in and can cause stumbling etc.
Old 06-08-2020, 04:56 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
Too high voltage can burn the points,
Old 06-08-2020, 08:12 PM   #7
53_mercLuke
The other weekend when I thought I fixed the issue but found my alternator bad the volt meter on the car read high but at idle it when back to 12 but then when I did a check on the system it wasn't charging at all. I thought about the points and everything but if it wasn't charging on my multimeter I don't think it was charging for awhile. My meter on the car is still the original with the wire running through it
Old 06-09-2020, 04:54 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
You are referring to a "volt meter on the car".
Last I knew, Mercury did not use a volt meter but an ammeter.
Just what do you have?
Old 06-09-2020, 07:21 PM   #9
53_mercLuke
I ment an ammeter
