05-29-2020, 08:04 AM | #1 |
36 Car Headlight Buckets
Hi, Can someone tell me if 36 car headlight buckets were used on 35"s and also trucks. Thanks
05-29-2020, 08:58 AM | #2 |
Re: 36 Car Headlight Buckets
!935 and 1936 cars use the same bucket. Different lens and rim ring.
05-29-2020, 09:07 AM | #3 |
The basic headlight buckets on '35 & '36 pass and some light comm. vehicles, and '38-'39 trucks, are the same, but in some cases there were different hollow centered mounting bolts used, as well as glass lenses and bezels.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-29-2020 at 09:13 AM. |
05-29-2020, 09:31 AM | #4 |
05-30-2020, 05:17 AM | #5 |
If you are talking about whether the 36 passenger headlight was used on the 36 pickup/truck, the answer would be no. The 1935 passenger bucket and the 36 passenger bucket were dimensionally the same but the 36 had a significantly shorter mount so without modification it would not work on a 35. The 36 passenger bucket used a different headlight lens and headlight door than the 35 passenger bucket as pointed out by others. The 35, 36, and 37 pickup/truck buckets used the same headlight lens and headlight door as the 35 passenger bucket. There were some differences in the location of the mounting bracket but they were all dimensionally the same. In 1938 and 1939 Ford used the 1935 dimension headlight bucket on their pickups/trucks but the 36 passenger bucket would have to be modified, again because of the short stand. In 1940 and 1941, Ford used the same dimension bucket as the 35 passenger car on the pickups/trucks but they had a factory seal beam set-up. The seal beam headlight doors are not the same as the earlier passenger cars and the 1940 and 1941 seal beam headlight doors are not the same as each other.
05-30-2020, 07:46 AM | #6 |
05-30-2020, 09:35 AM | #7 |
Thank you To All
08-14-2021, 07:06 PM | #8 |
Hello BW,
I am new to Ford Barn. I'm looking for 36 ford pass. car headlights. I was hoping to find complete set, but will start with parts. Do you still have buckets? If so, could you e-mail some pics. of the condition of them. [email protected] Like to make a deal if they are usable. Please contact me. Thanks, Marv |
08-16-2021, 07:39 PM | #9 |
Where is the correct measurement made to determine the diameter of '35-'36-'37 Pickup headlight buckets? Or do you just measure the diameter of the lense?
08-16-2021, 10:25 PM | #10 |
I was told that these Head Lights were 1935 Ford. Can someone please confirm that this is correct? I have since been told that these Headlights are 1936, not 1935. Last edited by mercman from oz; 08-17-2021 at 02:55 AM. Reason: Description change |
08-16-2021, 10:34 PM | #11 |
I know that these are definitely 1936 Ford Headlight Buckets. |
08-17-2021, 01:36 AM | #12 |
08-17-2021, 02:54 AM | #13 |
The Red Headlight is 1936. What year is the Cream Headlight, with the very long Mounting Bolt? |
08-17-2021, 03:46 AM | #14 |
Cream head light is 1935 pass car. Pickups and panel trucks are again different. Here is a pic of the '35-'37 pickup/panel head light. The big trucks again different as to the location of the mounting bolt.It is further back.
08-17-2021, 04:52 AM | #15 |
Thanks to "deuce lover", he has answered my Question "what year was my Cream Head Light in the above Post" as being correct for the 1935 Ford V8. Thank you. Regards Mercman <><
08-17-2021, 04:56 AM | #16 |
Picture of the 1935-1937 Ford Pick-Up/Panel Delivery Head Light, as submitted by "deuce lover". |
08-17-2021, 05:01 AM | #17 |
1935 Ford V8 Passenger Cars Head Light - Notice the very long mounting Bolt, unique to the 1935 Fords. |
08-17-2021, 05:44 AM | #18 |
The long mounting bolt is not unique to 1935 Ford passenger cars. It was also used in 1938-1941 Ford trucks.
08-18-2021, 11:57 PM | #19 |
The same basic bucket and the long mounting bolts were also used on COE until 1947. Later ones were the same as those used on 1941 trucks with the buckets having an internal assembly for fine tuning headlight aim adjustment.
- Last edited by Randy in ca; 08-19-2021 at 12:12 AM. |
