Old 05-27-2020, 12:58 PM   #1
kelly.ga
kelly.ga's Avatar
Angry oil pan modification
Once again, I got splashed with oil while changing the oil in my 47. i'm thinking about modifying the plug so I can put a smaller plug in it. Has anyone ever done this or does someone already make them. Or am I the only one that has this problem.
kelly.ga is offline   Reply With Quote
Old 05-27-2020, 01:32 PM   #2
19Fordy
19Fordy's Avatar
Default Re: oil pan modification
I bet you could easily weld or braze an oil drain plug bung onto your present pan.
This one looks good as it has a low profile.
https://www.amazon.com/ALLSTAR-PERFO.../dp/B07QYGMVT5
Old 05-27-2020, 03:35 PM   #3
marko39
See if plug is a pipe thread, if it is you can buy a bushing to have a smaller plug. Mark
marko39 is offline   Reply With Quote
Old 05-27-2020, 03:48 PM   #4
Tony, NY
Maybe one of these with the right thread would work. Drain valve.
https://www.ebay.com/itm/FUMOTO-T-20...EAAOSw4mNemM7s
Tony, NY is offline   Reply With Quote
Old 05-27-2020, 04:26 PM   #5
GOSFAST
GOSFAST's Avatar
Here's a couple ideas, ones we've done most recently on a number of Flathead pans. Relatively easy!
Thanks, Gary in N.Y.
P.S. I may have a couple bushings we fabricated here in stock still, these require welding however to install! You can use a "conventional" drain plug after the fix.
File Type: jpg Flathead Oil Pan-8BA Drain Plug Fix B.jpg (79.4 KB, 59 views)
File Type: jpg Flathead Oil Pan-8BA Drain Plug Fix C.JPG (63.5 KB, 56 views)
GOSFAST is offline   Reply With Quote
Old 05-27-2020, 04:31 PM   #6
Brian
Brian's Avatar
Early oil pans had a smaller drain bung. Somewhere in one of my oilpans, the large drain plug has been drilled and tapped to suit the smaller bung. Easy solution for you would be to modify your drain plug the same way. Loctite it back into the pan and from then on just undo the smaller plug.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 05-27-2020, 04:40 PM   #7
deuce_roadster
deuce_roadster's Avatar
I never have any problem, I do wear latex exam gloves but never had a mess or any splashing. How far does the oil drop before it hits your container? When the plug gets close to the last threads unscrew it quickly and hang on to it. You can put blocks under your catch pan so it is closer to the oil pan.
Old 05-27-2020, 04:41 PM   #8
hardtimes
hardtimes's Avatar
Look around. You will find different ideas/plugs for ‘fix’.
One type that has been available for years, is a plug with a drain valve built in. And it has a small ‘pipestub’ to attach a rubber drain tube.
Can be shut off/on easily and addresses the messy problem of oil changing. This plug just stays in place.
I can’t do pic here. But a search should find it.
hardtimes is offline   Reply With Quote
Old 05-27-2020, 05:05 PM   #9
Tony, NY
See my post above.
Old 05-27-2020, 05:36 PM   #10
oldford2
oldford2's Avatar
Come on Guys. these early Fords were simple so lets keep it that way.
Draining the old oil? messy problem of oil changing??
Your oil pan plug is (I assume) like my 46. Large. Just use a bucket, not a pan and block it up to within a few inches. Loosen the big drain plug so you can then reach in your rubber gloved hand and finish unscrewing it. Hold on to it until everything drains.
So why change Henry's design? Make things simple...new plug,? welding your pan?
JMO from an old Ford guy
John
oldford2 is offline   Reply With Quote
Old 05-27-2020, 06:04 PM   #11
kelly.ga
kelly.ga's Avatar
I looked at these and I really like the Dorman HELP 65128. no welding necessary. Thanks
Old 05-27-2020, 06:06 PM   #12
kelly.ga
kelly.ga's Avatar
i assume it has pipe threads. may look into that. Thanks
Old 05-27-2020, 06:08 PM   #13
kelly.ga
kelly.ga's Avatar
i like these too. no welding. Thanks
Old 05-27-2020, 06:12 PM   #14
kelly.ga
kelly.ga's Avatar
Distance is maybe a foot. The problem comes when the plug comes out, then oil gushes out all over my hand. arm, floor, and this last time in my eyes.
Old 05-27-2020, 06:15 PM   #15
kelly.ga
kelly.ga's Avatar
i looked at these. and i also just learned how to reply
Old 05-27-2020, 06:30 PM   #16
oldford2
oldford2's Avatar
Gary
I don't think that is a 47 pan like the poster is asking about
Old 05-27-2020, 06:37 PM   #17
Talkwrench
Talkwrench's Avatar
Its all I do. Also there is an advantage of having the larger hole, you can stick your finger in there for a good feel around.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 05-27-2020, 06:49 PM   #18
oldford2
oldford2's Avatar
Oh you Aussis are a fun bunch
Old 05-27-2020, 06:53 PM   #19
deuce_roadster
The stock drain plug threads are NOT pipe threads.
Old 05-27-2020, 07:32 PM   #20
cas3
i think the big plug is a good thing. oil rushes out carrying any crud that will go with the tidal wave, and you can stick your finger in to feel the floor of the pan. now that you know what to expect, just be ready for it
cas3 is online now   Reply With Quote
