Old 05-22-2020, 05:17 PM   #1
Robert/Texas
Robert/Texas's Avatar
Default Light Switch Problem
When I bought my ’28 roadster in 1989 the lights and horn were not working and there were problems with the associated wiring. I replaced the horn rod as the end of it was broken off and I replaced the wiring harness and other things with repro parts except that I used the original switch housing. I remember having trouble getting everything working at the time. Now, after 31 years I’m having new problems.
The horn started blowing because the soft metal switch spider was badly twisted and worn, and the retainer clip had fallen out. Also, the spider spring was of light gauge and damaged.
I jacked up the front of the car and put jack stands under the axle so it would be easier to remove the engine splash pan before starting to work on this. I replaced the switch spider with a good one and a spring purchased from one of the vendors. I assembled this with the spider and the switch handle in the correct orientations. (I did think at the time that the spring seemed hard to compress.) Next I checked to see that the lights and horn worked and that I could feel the clicks in the light handle for the high and low beams and parking lights. Everything worked and I turned the steering wheel to the full right and left positions several times. Everything still worked and was satisfied that the job was finished.
Not so, when I took the car out and went around the third corner, the light handle turned to the left along with the steering wheel. I know that the harness was ruined as the wires were ripped out of it. I tried to reassemble it anyway but found that it is impossible to install the spider in the correct orientation. I believe that the plastic switch has somehow slipped in the metal housing. I can’t figure out how this could have happened.
I’d like to get this fixed but I’m not sure where to start.
All help and suggestions will be much appreciated.
Thanks, Robert
Robert/Texas is offline   Reply With Quote
