Old 05-14-2020, 03:09 PM   #1
shew01
shew01's Avatar
Default Distributor Oiling
As I understand it, there are two places to oil the distributor:
1. The hole in the can screw
2. The brass sliding tube at the base of the distributor
Both holes are small. What do you use to get oil into them?
I understand that Vaseline can be used on the points cam. Should any lubrication be added to the stop of the rotor? If so, what should be used?
shew01 is offline   Reply With Quote
Old 05-14-2020, 03:24 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Distributor Oiling
point cam lube,oil- fill side tube and squirt some in top hole.
www.whidbeymodelaclub.com
Old 05-14-2020, 04:04 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, as above, -use a squirt oil can that you can add a few drops of oil. Ironically, it does not take but a few drops at regular intervals (i.e: 1,000 miles) to keep the bushings happy.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-14-2020, 04:07 PM   #4
Jack Shaft
Di electric grease works well if you can find point cam lube.
Jack Shaft is offline   Reply With Quote
Old 05-14-2020, 04:20 PM   #5
shew01
shew01's Avatar
It turns out I have some cam shaft lube.
I’ve tried oiling, but I don’t think any oil is actually getting in the distributor. This is my oiler.
Is there something better to use?
Old 05-14-2020, 04:21 PM   #6
shew01
shew01's Avatar
And does the rotor need any lubrication between it and the distributor cap?
Old 05-14-2020, 04:52 PM   #7
Big hammer
Originally Posted by shew01 View Post
and does the rotor need any lubrication between it and the distributor cap?
Sent from my iphone using tapatalk
no !!
get a bigger hammer tap done
Old 05-14-2020, 05:07 PM   #8
Bill Goddard
Bill Goddard's Avatar
I use the tube of lube oil from A suppliers. Also, I have started to remove the dist housing from the head once a year and look for rust in the hole at the interface of the dist shafts. They cake up with rusty mud and the first time I found it I couldn't believe the engine ran. It showed no problems before. The second time was 9900 miles later and it was all rusted up again.
Bill Goddard is offline   Reply With Quote
Old 05-14-2020, 05:08 PM   #9
Patrick L.
Patrick L.'s Avatar
A little dab of point cam lube on each lobe of the cam.
A couple drops from from your oil cam to the shaft [ 2 places]
Nothing for the rotor
Old 05-14-2020, 05:17 PM   #10
Kurt in NJ
Kurt in NJ's Avatar
engine running too cold, trips too short to boil off moisture
I you fill the side oiler as per the instruction book (fill it full)the upper bushing gets lubed
the center button is carbon, pretty much self lubing, though a rusty rotor contact or hole worn in it will eat the carbon button
Old 05-14-2020, 05:41 PM   #11
shew01
shew01's Avatar
Filling the side oiler full only takes a couple of drops, and I just had the distributor off for cleaning. I would have thought it would take more than a couple drops, which is why I’m wondering if side oiler is plugged up or if I need a more proficient tool to oil it.
Old 05-15-2020, 08:31 AM   #12
1931 flamingo
1931 flamingo's Avatar
The hole in the cam screw only works IF the shaft below it has the hole also.
Paul in CT
Old 05-15-2020, 11:02 AM   #13
30 Closed Cab PU
The Cam screw hole was not original, is a modification to the screw and shaft to aid oiling the upper distributor bushing. If you reference the manual it instructs you to fill the oil cup to full where it will not take more, and during running the oil is supposed to migrate up into the upper bushing.
30 Closed Cab PU is offline   Reply With Quote
