Old 05-12-2020, 05:35 PM   #1
Pandersen33
Pandersen33's Avatar
Default Crab distributor initial setup
Im trying to install an electronic crab distributor -speedway 910-8353 in my 39 motor. The engine starts and runs but id like to get some more info on adjustments. Is this thing adjusted by loosening the 3 mounting bolts? Where are they normally set? My motor has no timing marks so without tearing it apart id like to how this thing is set up. Their tech support was very little help. Directions require a timing light which would require marks...
Pandersen33 is offline   Reply With Quote
Old 05-12-2020, 06:13 PM   #2
Mart
Mart's Avatar
Default Re: Crab distributor initial setup
Use a cable tie to determine a tdc mark. make a pointer. get a dial back or electronic timing light.
Start with this: https://youtu.be/dn446jjCVRg
Then watch this: https://youtu.be/XDlNSuW-47Q
Mart.
Old 05-12-2020, 06:45 PM   #3
JSeery
JSeery's Avatar
Yep, need to start with establishing a TDC mark on the pulley and fabricating a pointer.
Old 05-12-2020, 07:54 PM   #4
flatjack9
flatjack9's Avatar
Yes you loosen the 3 bolts to adjust timing, but without a pointer you are SOL.
Old 05-12-2020, 07:56 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
you could get close with a vacuum gauge, advance at idle to maximum vacuum, retard 1 inch of vacuum
has the advance curve been verified to suit your engines needs ---idle timing may be a compromise depending on total advance
yes from the picture at speedway the bolts are loosened and assembly is rotated
carry spare stock dist for breakdowns
Old 05-12-2020, 09:27 PM   #6
Newc
Newc's Avatar
Hi; Listen to Kurt about a spare... I just pulled a friend's bad pertronix and replaced it with my last' Bubba' crab, and is he happy. The electronic is a wall hanger now. So now I'm out of stock of the good ones. newc
Old 05-13-2020, 05:33 PM   #7
Pandersen33
Thanks for all the suggestions. Looks like ill be pulling it back apart!
Old 05-14-2020, 01:20 AM   #8
Mr 42
Mr 42's Avatar
I drilled a hole in one of the cam cover bolts, and silver soldered in a pointer in the bolt.
Then did the positive stop method, in same way as Mart.
Mr 42 is offline   Reply With Quote
Old 05-14-2020, 10:02 AM   #9
JSeery
JSeery's Avatar
What are you pulling apart?
