Old 05-07-2020, 09:17 AM   #1
Cecil/WV
Cecil/WV's Avatar
Default Paint code
can anyone help me with the paint code for a '50 Ford gray dash?? Thanks!
Cecil/WV is offline   Reply With Quote
Old 05-07-2020, 09:51 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Paint code
I can't help but isn't there a little silver in it??
I'm going way back with my memory.
Paul in CT
Old 05-07-2020, 10:39 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Your best bet if available is to remove the glove box door and have it matched at an auto paint supplier.
Old 05-07-2020, 11:43 AM   #4
Cecil/WV
Cecil/WV's Avatar
There isn't enough left to scan. This has been setting for 35 years!
Old 05-07-2020, 02:24 PM   #5
supereal
supereal's Avatar
Most old paint codes are useless now because paint formulas are vastly different. A really good body shop can create a very close match. Painting a dash usually requires removal, anyway to get an acceptable result, making testing any good spots not diminished by age or exposure possible.
supereal is offline   Reply With Quote
Old 05-07-2020, 02:47 PM   #6
34PKUP
34PKUP's Avatar
Even the inside of the glove box door, that doesn't see daylight?
34PKUP is offline   Reply With Quote
Old 05-07-2020, 02:50 PM   #7
fatso2114
I did mine with "silver argent " looks sharp it's a silver metallic
fatso2114 is offline   Reply With Quote
Old 05-07-2020, 03:00 PM   #8
35fordtn
35fordtn's Avatar
Cecil, tcp global would have the paint in the correct color
35fordtn is offline   Reply With Quote
Old 05-07-2020, 03:56 PM   #9
MplsMike
Hope this link works, your paint code might be here. Look through all of the pages that come up when you search on a ‘50 Ford.
https://www.autocolorlibrary.com/
MplsMike is offline   Reply With Quote
Old 05-07-2020, 06:18 PM   #10
rotorwrench
rotorwrench's Avatar
I've heard both good and bad reports on some of TCP Global's paint matches. They are about the only ones that will do it without a part to compare with.
Old 05-08-2020, 11:49 AM   #11
Cecil/WV
Cecil/WV's Avatar
Thanks for all the advice. I did get the PPG formula from a friend in NY who had redone his dash in the past. He had obtained the formula from the late Cecil Goff, former '49-'51 advisor for the EFV8 Club, sometime in the past.
Note: the dash is out of the car and has been blasted,
Old 05-08-2020, 01:51 PM   #12
Jersey Devil
Jersey Devil's Avatar
Cecil
Could you post the paint codes I am sure others, including me, would appreciate it.
Seemed to me the their were different dash paint finishes for the Deluxe coupes/sedans and the Custom coupes/sedans. Convertibles were also different.
Tom
Jersey Devil is offline   Reply With Quote
Old 05-08-2020, 05:28 PM   #13
tubman
tubman's Avatar
Interior paint color also varied with the exterior color.
Old 05-10-2020, 12:46 PM   #14
Cecil/WV
Cecil/WV's Avatar
Originally Posted by Jersey Devil View Post
Cecil
Tom
I have the mix formula for Tan and Gray, both in Acrylic Lacquer. That is not what I wanted. My paint shop is looking , this week, to se if they can match a single stage to it and then I will post the results!
Old 05-10-2020, 05:58 PM   #15
Jersey Devil
Cecil
Thanks for the reply, wait to hear.
Tom
Old 05-13-2020, 08:55 AM   #16
Cecil/WV
Cecil/WV's Avatar
Cecil
Tom
What I said I had couldn't be crossed over. Sorry, it was for Acrylic Lacquer, but didn;t show all that was necessary.
