Old 05-04-2020, 02:07 PM   #1
WilliamRieske
Default Newbe with a couple of questions
With my dad's passing in January, I inherited a 31 Model A coupe. The problem it is in Utah, I am in Arkansas. I have been disappointed in the professional transport options I have found, so I plan to drive out in two weeks and bring it home myself. Any suggestions for do's and don'ts would be appreciated.
Also the car has not been started in eight to ten years so suggestions for what to do before I turn the key would also be appreciated.
Thanks in advance
Bill
WilliamRieske is offline   Reply With Quote
Old 05-04-2020, 02:18 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: Newbe with a couple of questions
You can’t take a trip with it until you do a lot and get to know the car. You will spend a lot more trying to drive the trip than a carrier. Get it delivered home and then take your time playing with it. Goo d luck.
Jacksonlll is offline   Reply With Quote
Old 05-04-2020, 02:26 PM   #3
Charlie Stephens
Thanks in advance
Bill
Did you mean bring it home on a trailer or try to drive it home (bad idea)?
Charlie Stephens
Old 05-04-2020, 08:55 PM   #4
1930artdeco
1930artdeco's Avatar
Welcome to the club! If you have never driven one/worked on one before there will be a very steep learning curve. Here is my two cents worth:
1) Get a member roster from MAFCA/MARC
2) Drain all fluid and refill
3) hand crank the engine over before trying to fire her up.
4) If the tank has rusted or shellacked over, that will need to be fixed or the car will die repeatedly.
5) The oil probably has turned to sludge so the pan will need to be cleaned out
6) Check the tubes as they tend to blow occasionally
7) There is a guy on the barn who advertises transport of cars, may check him out.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-04-2020, 09:37 PM   #5
KansasRick
Your album photos shows the car on a flat bed heading home today. Is that right William?
KansasRick is offline   Reply With Quote
Old 05-05-2020, 12:46 AM   #6
Bill G
Bill G's Avatar
If you try driving a long distance in a 89 year old car that has not even been started in that many years, you probably won't make it very far. My short suggestion is don't do it, or the cost of rebuilding the engine will far outpace the cost of shipping. Any new owner of a Model A also needs some practice so that the downshifting, spark control, and GAV setting are familiar and somewhat second nature.
Bill G is offline   Reply With Quote
Old 05-05-2020, 07:27 AM   #7
chap52
chap52's Avatar
Sorry for your fathers passing.
My advice:
Have it shipped. Probably cheaper than going and getting it yourself. I had my A shipped from Virginia to Arizona for less than I could have driven there and towed it home. Considering time, fuel, food and motel stays...
Was picked up on a Friday morning and delivered the next Sunday. Quicker than expected.
Car was on an open carrier, no damage or issues.
As advised, it's driving a new adventure car by someone new to "A's"=more of an adventure than you may really want to experience...
Enjoy the adventure with your new A.
chap52 is offline   Reply With Quote
Old 05-05-2020, 09:13 AM   #8
DD931
DD931's Avatar
I have moved several cars with a Penske truck pulling a Penske trailer (not the two-wheel kind). Good equipment.
DD931 is offline   Reply With Quote
Old 05-05-2020, 01:54 PM   #9
DHZIEMAN
I trailered mine safely with some strong tie downs, well located on axles and also two for side to side movements! Also I covered the entire front of my 1930 with a plastic tarp and had it tied down very well to prevent "FLAPPING" on the body paint. I had all 4 wheels on the trailer and did not want to keep two on the ground as on these old cars, especially not familiar with tire quality, I got all wheels off the ground on the trailer. I was fortunate, I borrowed my neighbors trailer and kept it a week. Have a good vehicle, if the trailer has brakes, good to have brake controller in your truck. Also, in towing any vehicle, Tie downs can fool you and loosen. Early on in your adventure, stop more than fuel stops to check things over, make sure the car has not shifted and keep an eye on trailer tires too! Good luck on your adventure!
DHZIEMAN is offline   Reply With Quote
Old 05-05-2020, 02:26 PM   #10
RTPbee81
RTPbee81's Avatar
Shipping is probable the best option, I trailered mine from Iowa to NC, 1106 miles, thought the $1000 price tag to ship, was to steep, but with gas, trailer rental and hotel cost me a little over $1,150 but was much more enjoyable. lot of of thumbs up as people passed me on the highway...
RTPbee81 is offline   Reply With Quote
Old 05-05-2020, 02:42 PM   #11
Fred K OR
Another look at the situation. Normally it would be a good "vacation" to get out and drive across the country. But now, ??? don't know with the current situation.
When we did our huckster build a few years ago, we drove from Oregon to Michigan to pick up the wooden body. It was a great trip, took us about two weeks. We loaded the body in back of my pickup and tied it down well. BUT did not cover it with anything. Did not want the "flapping" to mess up the finish on the body-worked out great.
So just some ideas on a trip like this
Fred K OR is offline   Reply With Quote
Old 05-05-2020, 03:04 PM   #12
MAG
MAG's Avatar
In the past I have called ahead to reserve a UHaul Car Hauler, one way. That saves fuel. UHaul equipment is usually very dependable and the correct equipment to tie down the vehicle is present. As has been suggested, check tie down straps frequently. With a good tow vehicle I think you will be fine. Done it lots of times.
For what it's worth,.... don't try to start the engine until you have done the proper inspection as has been suggested.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 05-05-2020, 03:14 PM   #13
1928Mik
1928Mik's Avatar
Try this guy for supreme auto transport. He's all over the country, very meticulous....
Bill Squires
Bills Auto Transport
https://www.jalopyjournal.com/forum/...closed.614419/
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible 455 5 speed Restomod
1976 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 05-05-2020, 04:20 PM   #14
Joop
Joop's Avatar
On his profile page are pictures as mentioned before
He states bringing it home on a flatbed trailer
So he is on it's way
Joop is offline   Reply With Quote
