Old 04-28-2020, 03:24 PM   #1
Pandersen33
Pandersen33's Avatar
Default Reverse eyed spring with Mitchell OD?
Has anyone done this? I am working on a 35 sedan and would like it to sit just a bit lower. However the Mitchell OD doesnt look like it has too much more room over it. Just curious if I need to look at more cutting or if another approach is necessary. Thanks
Pandersen33 is offline   Reply With Quote
Old 04-28-2020, 03:32 PM   #2
37 Cab
37 Cab's Avatar
Default Re: Reverse eyed spring with Mitchell OD?
I have a Mitchell in my 37 with reversed springs. I made a box 1 inch higher than the tunnel for clearance. 1+ wider on both sides for side to side movement.
Tommy
37 Cab is offline   Reply With Quote
