04-11-2020, 03:20 PM | #1 |
Pilot bearing fit
Is the pilot bearing to the transmission input shaft Press fit? My brand new pilot bearing ID to Transmission input shaft seems to be a very tight press fit.
04-11-2020, 03:48 PM | #2 |
Re: Pilot bearing fit
Yes it is a press fit and the outer part does not spin.
04-11-2020, 04:33 PM | #3 |
The pilot bearing is a press fit to the flywheel, but not a press fit to the input shaft of the transmission. If it was you would not be able to install the transmission.
04-11-2020, 04:37 PM | #4 |
Check the dimensions to see which part is wrong. Are you sure there are no burrs anywhere? it should be a slip fit on the transmission.
04-11-2020, 07:16 PM | #5 |
What Midgetracer and J said.
04-12-2020, 10:23 AM | #6 |
04-12-2020, 11:42 AM | #7 |
Does anyone have an idea what the transmission input shaft diameter should be?
My shaft is .696 diameter and my bearing is .667 ID. |
04-12-2020, 02:41 PM | #8 |
Well, thats a heck of a lot more than a press fit. What number is your bearing ?
04-12-2020, 03:00 PM | #9 |
Go find a bearing that fits. That was a very common one used on many makes and models of vehicles. My model A my tractor and a mustang I once owned had the same pilot bearing. How was the fit on the old bearing or did things get changed out? I went out and measured an A input shaft and see .6562. So what is your shaft out of? You apparently have the correct bearing for sure.
04-12-2020, 03:05 PM | #10 |
The bearing is A7600 per the package it came in.
04-12-2020, 04:01 PM | #11 |
Something is not right... The A7600 bearing is a common bearing in Fords up to the 60's and beyond. ID .667. As someone asked, what is the shaft out of?
As an alternative you could use the bronze replacement bushing and ream it out to fit? https://www.macsautoparts.com/ford_m...for-a7600.html |
04-13-2020, 12:39 AM | #12 |
I would take some emery cloth and sand the shaft. According to your measurements, you need about.029” I had a new nors shaft that wouldn’t go, and that’s what I did to get it to fit. Didn’t take much time to do.
04-13-2020, 12:46 AM | #13 |
Make sure the rest of the part is correct before modifying it.
04-13-2020, 10:28 AM | #14 |
IMHO, .029" is an awful lot of sanding. My choice would be to first side by side compare you have a compatible input shaft; which your problem suggests you dont.
Assuming it will work, go with the bronze bushing and size it as necessary. |
04-13-2020, 04:03 PM | #15 |
Bratton's catalog description: TRANSMISSION MAIN DRIVE GEAR - U.S. made. The end of the shaft where the pilot bearing (11550) fits must be .668 diameter. If worn more then .002 (.666) then the shaft must be built up or replaced. A poor fit will cause the transmission to jump out of high gear. Will not fit Early 1928 transmission boxes.
04-13-2020, 04:39 PM | #16 |
Anew bearing has an id of .670 Trans input shaft should be between .667 to .669
04-14-2020, 10:57 AM | #17 |
17mm = .669"
04-14-2020, 12:10 PM | #18 | |
04-14-2020, 12:59 PM | #19 | |
04-14-2020, 01:23 PM | #20 |
