Old 04-04-2020, 01:06 PM   #1
deuce295
deuce295's Avatar
Default Rear main oil pan seal
Have a new oil pan gasket set and it comes with two different seals for the rear main cap. One has to be squeezed in to work the other will fit but not as tight. Which should be used. I noticed the one I took off was the bigger one and the rear of the pan had cut into it pretty deep, thinking maybe the wrong one.
Any input appreciated.
deuce295 is offline   Reply With Quote
Old 04-04-2020, 01:14 PM   #2
briphaeton
Default Re: Rear main oil pan seal
I've used the over sized cork that I put a beveled edge on so it squeezes into place.
briphaeton is offline   Reply With Quote
Old 04-04-2020, 01:33 PM   #3
kenparker
kenparker's Avatar
I use the thicker/wider one and it is a tight fit. Once pan is on and squeezed the cork even tighter it dont leek. ken
kenparker is offline   Reply With Quote
Old 04-04-2020, 02:43 PM   #4
Jack Shaft
wrap it around a beer can with a rubber band the night before..or use super snot (weather strip adhesive) to hold it in place if you drink the beer..
Jack Shaft is offline   Reply With Quote
Old 04-05-2020, 10:11 AM   #5
Will N
Will N's Avatar
There are two versions of the rear main cap; one is forged and the other is cast, which was introduced in April 1929. Ford was always looking to cut costs throughout the production of the A. Could it be that the cast version has a larger radius where it seals to the oil pan, needing the longer seal?
Will N is offline   Reply With Quote
Old 04-05-2020, 12:22 PM   #6
PC/SR
One of the caps referred to by Will N has a wider "groove" for the seal to fit into. I think, but do not truly recall, that the later caps has the wider groove. Us the seal that fits best, ie, goes in with just some resistance. No need to jam a wide one in a narrow groove. Lots easier if you pre form the seal as JShaft says. I put mine in a tuna can, keep a couiple in there all the time.
PC/SR is offline   Reply With Quote
Old 04-05-2020, 01:20 PM   #7
redmodelt
redmodelt's Avatar
The cork rear seal is longer then needed and will need to be shortened a bit, go at it slow so you don't take too much off. Also put a bit of sealer at the ends.
Old 04-06-2020, 12:35 PM   #8
deuce295
deuce295's Avatar
Appreciate all the replies. Both seals were the same length and I used the one that is slightly thinner and slightly narrower. I trimmed the length to exactly 6 11/16" and it fits really nice, got this dimension from the leakless pan gasket PDF file. With the pan back on I can see that it just squeezes down where the other one that was slightly thicker was actually being cut into by the back edge of the pan. Much better fit and leak free. Thanks again for everyone's input.
Old 04-06-2020, 06:03 PM   #9
Dodge
You can also use an early small block chevy front timing cover seal which is neoprene.
Its the 1/4 thick one, trim to fit and a dab of silicone at edges.
Dodge is offline   Reply With Quote
