Old 03-30-2020, 07:54 AM   #1
rockfla
rockfla's Avatar
Default Been dabbling in Stainless trim repair
SO my first start at repairing Stainless Steel trim. Here are a couple of dents that are "Almost" done and ready for buffing. Before and afters
Old 03-30-2020, 07:56 AM   #2
rockfla
rockfla's Avatar
Default Re: Been dabbling in Stainless trim repair
PLUS one I didn't take a picture of BUT was creased and bent by getting pinched in the passenger front door at some point, almost buffed to perfection.
Old 03-30-2020, 08:17 AM   #3
Zax40
Zax40's Avatar
Nice! What tools are you using for the repairs?
Zax40 is offline   Reply With Quote
Old 03-30-2020, 08:27 AM   #4
flatford8
flatford8's Avatar
Nice!!....there’s some video on YouTube channel “Coldwarmotors”. He does a lot of stainless repair......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 03-30-2020, 08:38 AM   #5
rockfla
rockfla's Avatar
Lol....anything that looks like it will work for what I need to accomplish. I have a trim anvil & Hammer from Eastwood, I also use various punches, Awl, screwdriver, Taper Pins, Nylon stock, railroad track, wood, wood dowels, file, 220, 300, 400 wet/dry sandpaper...... again whatever looks like it will work. I have found the "closer"" you get to getting the "final" result you want, the "softer" the materials (nylon & wood) the better!!!! OH and finally a 1 hp 10" buffer with grey and white rouge.
Plus a lot of "technique" involved and in "some" instances I don't use the hammer at all!!! Just hand strength works in some cases.
Old 03-30-2020, 09:23 AM   #6
RalphM
RalphM's Avatar
Nice work! I tried a cowl band from a model A, it came out ok, but not that nice.
I have a 47 coupe I’m working on that needs some trim repair. Maybe I’ll send it to you
RalphM is offline   Reply With Quote
Old 03-30-2020, 09:34 AM   #7
rockfla
rockfla's Avatar
Be happy to give it a whirl for you!! Send me a few pictures [email protected]
Old 03-30-2020, 12:23 PM   #8
Mart
Mart's Avatar
Rock, I take my hat off to ya. That doesn't look easy. Have you seen Scott at Cold war motors do that sort of thing? That is the only time Ive seen it done and I was really impressed at how hard it is but he was making it look easy.
Well done.
Mart.
Old 03-30-2020, 01:48 PM   #9
rockfla
rockfla's Avatar
Well done.
Mart.
Thank you Mart that was very kind of you, its sort of like catching Sheephead fish, you have to set the hook a split second before he bites it!!! To say...... you have to sort of feel and know when to stop pecking just before its too late!!!! You must'nt be in any hurry!!! AND the one dent on the piece that had two in one area was/is much harder to deal with and I am "still" pecking at it, about 95% done BUT IF you really look at the big horizontal dent (first picture, right hand dent)...it has three spots were it looks like someone with a "nail" pushed them in, those are extremely difficult to deal with!!!!! AND For some reason the "after" picture of the third picture, first post WILL NOT upload for anything, I've "unlocked it" and tried three times and it will not up load
Old 03-30-2020, 03:18 PM   #10
blucar
blucar's Avatar
I have dabbled around with some SS trim repair, had very good luck with the finished product.
A friend of mine showed me a neat trick, using a drill press, chuck up whatever tool you are using to work the dent out, using the drill press to push the dent (s) in lieu of beating them out with a hammer/mallet.
Bill.... 36 5 win cpe
Old 03-30-2020, 03:53 PM   #11
rockfla
rockfla's Avatar
That's a cool Idea, I'll have to try that too.
Old 03-30-2020, 06:26 PM   #12
GaryU.
GaryU.'s Avatar
Second the drill press idea. Works good!
GaryU. is offline   Reply With Quote
Old 03-31-2020, 12:11 AM   #13
Tinker
Tinker's Avatar
Nice work!
Old 03-31-2020, 12:20 AM   #14
RalphG
RalphG's Avatar
Well done.
Mart.
Scott makes everything look easy. I've tried to copy his techniques but nothing I do ever turns out that well.
RalphG is offline   Reply With Quote
Old 03-31-2020, 07:56 AM   #15
Mart
Mart's Avatar
^^ Same here, Ralph. The "your results may vary" never rang truer than when trying to emulate Scott.
Mart.
Old 03-31-2020, 08:51 AM   #16
51woodie
51woodie's Avatar
I wanted to polish up some of the SS trim on my '46 Deluxe, as it was scratched and dull. I bought a buffer, buffing wheels and polishing compound from Princess Auto, (Harbor Freight in USA) to see what I could do to clean up the trim. I perused several videos on u-tube and went at it. Good success with bringing the shine back on the parts I worked on. For the trim on the side of the body, I masked the body at the top and bottom edges of the trim, then used a 4" dia. buffing wheel mounted on my 3/8" drill, with the wheel running parallel to the trim for polishing. I could have done a better job by removing the trim and polishing on the big buffer, but I didn't want to risk damaging the trim or paint. The picture is of the tail and park light trim
51woodie is offline   Reply With Quote
Old 03-31-2020, 08:51 AM   #17
hotcoupe
hotcoupe's Avatar
I have restored several S.S. items, it requires a lot of time and concentration. I use a lot of different techniques and tools, one of the most useful tools is a urethane block that i use as a dolly. It will support the surrounding metal while you move the displaced metal without stretching it. Very useful when you're working on hubcap skins that are only 0.012" thick. I tried to post a couple of images, but failed.
Tom
hotcoupe is offline   Reply With Quote
Old 03-31-2020, 09:49 AM   #18
Cecil/WV
Cecil/WV's Avatar
I had a '55 Ford in the late '50's that got rear 1/4 panel damage and I watched the body man trying to install the 1/4 side trim and he damaged it snapping it on the clips, enraged, he tore it off, totally destroying it, and ordered another new trim piece. Today, it would have been easily repaired!
Cecil/WV is offline   Reply With Quote
Old 03-31-2020, 11:43 PM   #19
RalphM
RalphM's Avatar
These are the worst pieces on the 47 I’m working on.
File Type: jpg E5946D07-6B4F-4533-971C-496C62033B90.jpg (31.1 KB, 21 views)
File Type: jpg D5A0608F-97D5-40C0-AD4F-BF8CCE33B844.jpg (42.4 KB, 19 views)
Old 04-01-2020, 12:20 AM   #20
cas3
back in my tri5 chevy days i bought side trim from a guy that thats all he did was fix 5-6-7 stainless trim. had a 2 car garage full of it, and made a nice living with very little $ in tools
