Old 03-21-2020, 05:43 PM   #1
28RPU
28RPU's Avatar
Default 1934 flathead V8 block & heads
City: Flintville
State: Tn
Price: 150
I have most of a 1934 flathead V8 engine. I have the block/main caps with exhaust manifolds, all the head studs. I have the crank with rods and pistons, I have he two cast iron truck cylinder heads, the camshaft, most of the valves and lifters. I have the flywheel and clutch, and the front cover. I do not have the rest of it. I thought I had the oil pan but can't locate it. This engine was holding antifreeze when it was together so I don't think the block is cracked but I have not had it tested, its just been stored away for years. So, as is, where is, pickup in south central Tennessee. $150
Don’t pick a fight with an old man. If he is too old to fight, he’ll just kill you.
28RPU is offline   Reply With Quote
