Old 03-19-2020, 06:53 PM   #1
dschwartz
Default Coil wires
Coil wires green wire to negative and brown wire to ground is this right? Should It be brown wire to negative and green wire to ground
I am running a angle drive distributor with a Mallory electric ignition
dschwartz is offline   Reply With Quote
Old 03-19-2020, 06:57 PM   #2
JSeery
JSeery's Avatar
Default Re: Coil wires
No idea on the colors you are referring to, but on a 12v system the ignition (power) connects to the (+) terminal and the (-) terminal connects to the distributor/points/condenser.
Old 03-19-2020, 08:33 PM   #3
19Fordy
19Fordy's Avatar
This will help, I think.
https://www.youtube.com/watch?v=-Wg2bYPLLpc and
https://documents.holley.com/mallory...7_38_45_47.pdf
Old 03-20-2020, 10:48 AM   #4
rotorwrench
rotorwrench's Avatar
Colors depend on who designed the wiring harness. If they made a diagram then that would tell you otherwise one should go to the distributor and hopefully the other goes to the ignition switch.
Old 03-20-2020, 10:54 AM   #5
deuce_roadster
deuce_roadster's Avatar
Your points go to ground, if you have neg ground system, neg wire goes to distributor, likewise if Pos ground, Pos wire goes to distributor. Regardless of wire insulation color. Makes it easy to remember if you are running points. I have no idea what electronic units use.
Old 03-21-2020, 11:48 AM   #6
deuce lover
deuce lover's Avatar
Brown :to ground,
Green :to coil negative
Red : to coil positive.
deuce lover is offline   Reply With Quote
