Old 05-23-2010, 11:17 PM   #1
kevinanderson
Default 50lb oil pressure sender
i read somewhere that a willys unit was a better than one advertised in the ford catalogs. is this true? can't find that web site. can someone point me in that direction. Have a SW mechanical unit, but want the original one to work too. thanks
kevinanderson is offline   Reply With Quote
Old 05-23-2010, 11:31 PM   #2
34fivewindow
34fivewindow's Avatar
Default Re: 50lb oil pressure sender
Here is the Standard Brand 50lb sending unit part # PS-60, this will replace the stock ford 50lb sending unit, you can get this at NAPA parts stores......Ed
34fivewindow is offline   Reply With Quote
Old 05-23-2010, 11:56 PM   #3
Mike in AZ
Mike in AZ's Avatar
you can try kaiserwillys.com...they show the sender in their catalog....Mike
Mike in AZ is offline   Reply With Quote
