Old 02-22-2020, 12:08 PM   #1
jwaldrich
jwaldrich's Avatar
Default 6 V Positive Ground
On a 6 volt positive ground flat head V8, and if everything is working correctly, can I remove the negative cable from the battery while the car is running and expect the car to continue to run on the generator?
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
