Old 02-03-2020, 10:29 PM   #1
37 Coupe
37 Coupe's Avatar
Default Champion W-20 plug
Would a Champion W-20 plug be a good runner in a Model A engine that probably has seen better days,probably needs at least rings and valve job,never bored. I have 4 W-20 that came with it.Thank You. Also have the 3X plugs.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 02-04-2020, 08:12 AM   #2
Jim Baskin III Pa.
Jim Baskin III Pa.'s Avatar
Default Re: Champion W-20 plug
37 Coupe ,they are a industrial plug with a high heat range
http://www.federalmogul.com/digitala...RangeChart.pdf
Jim Baskin III Pa. is offline   Reply With Quote
Old 02-04-2020, 12:16 PM   #3
katy
katy's Avatar
I have Champion W-18 plugs in my CCPU and they run fine. The chart that Jim B linked to shows they have a heat range of 7 which is the same as it shows for the W-20 plug, although the W-18 has a reach of 3/4" while the W-20 has a reach of 5/8".
Old 02-04-2020, 12:31 PM   #4
37 Coupe
37 Coupe's Avatar
I noticed the shorter reach compared to the 3X plugs I have but also different plug gap design.
Old 02-04-2020, 12:41 PM   #5
katy
katy's Avatar
The modern 3X plugs are a reproduction of the old ones and have the "bent wire" ground electrode which is designed to drain any oil accumulation away from the gap. The oil accumulation occurs in old, tired engines, aka oil burners.
Old 02-06-2020, 01:26 AM   #6
dave in australia
I use W-20's and have never had a problem with them. The engine in my Tudor was getting on a bit, and would get a bit fumy when hauling up a long climb, but the plugs never fouled.
dave in australia is offline   Reply With Quote
Old 02-06-2020, 09:42 AM   #7
rotorwrench
rotorwrench's Avatar
The shorter reach likely helps keep them from fouling for a oil burner.
