Old 02-01-2020, 07:13 AM   #1
pineyjd
Default 29/30 speedometer cable ?
I bought a 1/2 cable to replace the broken one, the old one had round shaft at transmission,the new one is different end.in some of the catalogs they show separate round end ? do you have to cut end off and put round end on ?.
pineyjd is offline   Reply With Quote
Old 02-01-2020, 04:09 PM   #2
loubob
Default Re: 29/30 speedometer cable ?
Look at the speedo cables on page A-180 in Snyder's catalog.
loubob is offline   Reply With Quote
Old 02-01-2020, 04:25 PM   #3
redmodelt
redmodelt's Avatar
Or change the drive at the driveshaft end to match the cable you have now. If you cut the end off and install a different one, the cable might be too short.
Old 02-01-2020, 07:42 PM   #4
Mark in MT
Cables for oval faced speedometer have a round, flagged end on the drive end and a .124 square end on the speedometer end. These use a 1/2" dia. housing. The cables for the round faced speedos have a .104 square on each end, they use the smaller diameter housing. You will some times find that someone miss matched the parts and it is not correct. Snyder's used to sell special cables that had the ends made so that you could use a round speedometer with a oval type drive, and vice versa. I don't know if they are still available. Easiest way to correct is to change the shaft in the drive on the torque tube to match the speedometer type, then get the proper cable.
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
