Old 01-06-2020, 10:51 PM   #1
trentclark
trentclark's Avatar
Default 47 pickup tranny
I have a 47 pickup with an 8BA and want to get it on the highway. the standard 3 speed is slow. what is the best standard tranny to connect to the 8BA. I appreciate your help. God Bless
trentclark is offline   Reply With Quote
Old 01-07-2020, 03:24 AM   #2
tubman
tubman's Avatar
Default Re: 47 pickup tranny
If by "slow", you mean that the top speed is limited and it is unsuitable for highway use, the problem is the rear-end ratio not the transmission. All contemporary Ford transmissions that would fit your vehicle have a top gear ratio of 1:1, meaning they would all have the same top speed. You need to change out the rear end for one with a higher (lower numerically lower) rear end. For example, change from a 4:11 to a 3:54. You can change the gear set in the original rear end or get a complete assembly with a more suitable ration out of another similar vehicle. Or you could do some modification to the vehicle to replace the existing rear end with one out of a later model vehicle with a more suitable ratio.
You also could change the transmission for one from a later vehicle with an overdrive top gear, such as a Borg-Warner T5. Many have done this, but it a relatively complicated swap requiring aftermarket parts and some custom fabrication. Since your pickup has an open rear drive instead of a torque-tube (like the cars) changing the rear end is a little less difficult.
It takes a little research and planning to come up with a satisfactory combination. Once you decide which way you want to go, there is a lot of information available (here and other places) that will be helpful in your obtaining the desired outcome.
Old 01-07-2020, 06:07 AM   #3
Mac VP
Mac VP's Avatar
The 1949-50 Mercury overdrive transmission would be a pretty easy swap into the 46-47 pickup truck but you would have to find a column shifter to work with it since it’s a side loader type that is made for the steering column shifter. Back in the day, Hurst made a floor shift conversion kit for the Merc overdrive but it would be a tough item to find now. Perhaps one of the available kits made these days could be adapted.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 01-07-2020, 09:43 AM   #4
Charlie ny
Mac's got it.........the Merc OD drops a 4:11 to about 3:00. No aftermkt shifters for
this specifically anymore but I've done two conversions using the Spark o Matic shifters
(swap meet stuff) and a bit of adaptation...no big deal. Lots of these Merc OD trans are out there.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 01-07-2020, 11:31 AM   #5
Tim Ayers
I'd assume the original truck rear end has 4:11 or lower gear ratio, no?
Would it be easier to swap the rear gears vs. adapting a different trans?
Old 01-07-2020, 11:53 AM   #6
FortyNiner
FortyNiner's Avatar
I would give these folks a call about a replacement ring/gear set: https://www.randysworldwide.com/
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 01-07-2020, 12:06 PM   #7
trentclark
trentclark's Avatar
By slow I mean 45 mph top speed in 3rd gear. I have a 9" with 3.55 in the rear. Ill look around for a 49-50 Merc OD.
Old 01-07-2020, 12:07 PM   #8
oldskool
oldskool's Avatar
if your 3 speed is open drive I would put a later rear like an 8in ford with 3:50 3:25 gearing,i had a 46 pu w/4speed open drive,replaced rear with an 70s torino rear and ran 65 mph, just had to mount new spring perches easy peasy,if you can locate a 68-72 bronco rear it will have the same wheel bolt pattern.
oldskool is offline   Reply With Quote
Old 01-07-2020, 12:10 PM   #9
Hal Beatty
Hal Beatty's Avatar
With 3.55 gears in the rear end you should be capable of well over 45 mph in 3rd. What kind of rpm are you turning at that speed?
Hal Beatty is offline   Reply With Quote
Old 01-07-2020, 12:13 PM   #10
Tim Ayers
Agreed. Regardless of your transmission, 3rd gear is a 1:1 ratio. 3:55's are a nice gear set. Something else seems to be amiss.
My dad has a '49 F1 with heavy duty 3 speed and 4:11's and it will do 65 all day long.
Old 01-07-2020, 12:29 PM   #11
Mart
Mart's Avatar
I have a 3 speed in my 41 and 3.54 ears, with 6.50:16s. It runs nice at 45 and will go quicker if I want.
If your truck tops out at 45 there is something not right. It should go a lot quicker than that as standard.
I'd suggest you look at the motor first, it must be very short on power or there is something stopping it from revving through the range.
Mart.
Old 01-07-2020, 01:17 PM   #12
alanwoodieman
51 merc engine, 77 b cam, 3 speed 28 tooth cluster (car) 9" with 3.25 gear set, runs easy at 60 mph, I have had it a lot faster! I would change out the 3:55 for a 3:25 easy change for a 9" just how hilly is your area?
alanwoodieman is offline   Reply With Quote
Old 01-07-2020, 01:38 PM   #13
Sid
Sid's Avatar
What are you running for a tire? My 49 F! with a stock 239 +.100 will run all day 70 mph 3.25 9" rear. 275/60/15 rubber 28" You may even want to consider a S10 5 speed.
Sid is offline   Reply With Quote
Old 01-07-2020, 02:22 PM   #14
Kurt in NJ
Kurt in NJ's Avatar
A60hp with 4:44 rear I had would do 74mph, either your brakes are dragging or the engine is low on power
Old 01-07-2020, 02:28 PM   #15
Tim Ayers
Agreed. Something is wrong.
Old 01-07-2020, 03:05 PM   #16
Mart
Mart's Avatar
I think the OP has twigged what we have been saying, he has posted another thread saying his 8BA is down on power.
https://www.fordbarn.com/forum/showthread.php?t=275006
Mart.
Old 01-07-2020, 05:28 PM   #17
raybee
If you don't have the power to pull a 3.55 rear gear over 45 MPH, an overdrive will be totally useless to you. You need to find out what is wrong with the engine. Ray
raybee is offline   Reply With Quote
Old 01-07-2020, 06:32 PM   #18
Sid
Sid's Avatar
If everything is right with the engine,compression,timing,fuel pump and you are getting full throttle make sure mice aren't squatting in your exhaust system. Even with a 3.55 gear the truck should run 65 mph @3,000 rpm with a 26.5 tall tire thereabouts.
Old 01-07-2020, 11:08 PM   #19
trentclark
trentclark's Avatar
thanks for the replies. something is a miss. I have another thread trying to figure out a power issue and maybe they are the same issue. the tires are 255/60R15's. I dont have a tach but will mount one this weekend so I can see. it revs up real nice in idle but just bogs down on the road. I do have a hesitation when I punch it, it almost dies like its getting too much gas. has a big sucking noise. if I east into it, it accelerates well.
the exhaust is new so all is clean, or should be. I will check.
ill check compression too. havent done that yet.
ill post photos when I remember how again. ...God Bless
Old 01-08-2020, 11:22 AM   #20
Sid
Sid's Avatar
I'd almost bet you have an issue with the carb. It could have an issue internally especially if it isn't driven much and has ethanol fuel in it. I would put another carb. on there from a running engine that you are positive works and that will rule that out. It may even be float level. From what I understand is the throttle blades are open and there is a lack of fuel atomizing in the venturi.
