Old 01-01-2020, 07:23 AM   #1
David R.
Default Engine Stand
Pulled the engine out of my AA yesterday. Wondering if anyone has any clever ideas for a way to adapt to my engine stand?
David R. is offline   Reply With Quote
Old 01-01-2020, 08:35 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Engine Stand
Most of the vendors sell this adapter:
https://www.brattons.com/engine-stand-adaptor.html
Old 01-01-2020, 08:36 AM   #3
kenparker
kenparker's Avatar
what dles your engine stand look like? Pictures??? ken
kenparker is offline   Reply With Quote
Old 01-01-2020, 09:39 AM   #4
David R.
Like this
File Type: jpg 0A20CE42-E331-48E2-9752-0025802C4451.jpg (39.5 KB, 239 views)
Old 01-01-2020, 11:04 AM   #5
katy
katy's Avatar
Homemade version:
Old 01-01-2020, 11:44 AM   #6
kenparker
kenparker's Avatar
dont have diagram but here arecouple pictures to show my adaptor. Do not advise hanging engine on this type of stand with the flywheel attached ken
Old 01-06-2020, 07:42 PM   #7
28Danby
Just finished up my engine adapter today. I’ll let you know if I find the motor on the floor in the morning lol
File Type: jpeg A7E55F80-2CC6-4AFA-AB60-40E29DA500F5.jpeg (25.2 KB, 247 views)
File Type: jpeg 8987067B-652F-4CE9-9D76-B1AD5DDA3CBE.jpeg (24.9 KB, 207 views)
28Danby is offline   Reply With Quote
Old 01-06-2020, 08:31 PM   #8
David R.
I went ahead and pulled manifold so I could lay it on that side and pulled flywheel. Then hoisted it back up and took of flywheel housing. Then was no problem bolting to stand on flywheel end. Working on disassembly and assessment. Got down to the last three head studs before breaking one. Looks like pistons are 060 over and 2 & 3 have been sleeved.
Old 01-06-2020, 08:47 PM   #9
BillEbob
BillEbob's Avatar
I have zero welding skills but I sure don’t see that that attachment is worth the better part of a $100 bill! What am I missing?
BillEbob is offline   Reply With Quote
Old 01-06-2020, 10:44 PM   #10
Dave1931Pickup
Not a real good picture of the engine but I assembled mine without the flywheel and housing. I was skeptical of attaching it to the side with the adapters that are sold.
Dave1931Pickup is offline   Reply With Quote
Old 01-07-2020, 09:34 AM   #11
jhowes
I'd be more concerned about the three wheeled engine stand. I had one fall on me and nearly did a lot of damage to my leg. Only 4 wheeled versions now. Jack
jhowes is offline   Reply With Quote
Old 01-07-2020, 10:01 AM   #12
28Danby
I have quite a bit of fabricating and machining experience and I can tell you there is probably about $10-15 worth of material but the real money is in labor. These probably aren’t massed produced but done by hand in batches and by the time the steel is cut, bent in a brake, drilled, welded and what not then finally painted, the labor costs add up.
Old 01-07-2020, 11:24 AM   #13
katy
katy's Avatar
My engine stand was a 3 wheel version but I converted it to a 4 wheel with a piece of 3" channel iron.
Old 01-07-2020, 11:51 AM   #14
Russ/40
Russ/40's Avatar
It's a very heavy built adapter. May seem like a lot, but if you build an engine or two, or just need to pull the pan on an engine out of the car, you will be happy to have it.
Russ/40 is offline   Reply With Quote
Old 01-07-2020, 07:36 PM   #15
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have the same engine stand as pictured. It is a cheap one from Harbor Freight. I was able to use 3 of the 4 arms that came with the stand by bushing down the eyelets to fit the bolts going into the rear of the block where the flywheel housing bolts on. It is a tight fit but it works. Buy 3 bolts and 3 bushings and you can use what you have....
Dick M is offline   Reply With Quote
Old 01-07-2020, 10:31 PM   #16
David R.
I bolted to top two housing bolt holes directly through plate and used 2 of the arms in lower holes.
Old 01-09-2020, 09:22 AM   #17
DD931
DD931's Avatar
I would get rid of that three wheel engine stand ASAP. It's just a disaster waiting to happen. I just bought a nice four wheel one from Harbor Freight. Works a charm!!
DD931 is offline   Reply With Quote
Old 01-09-2020, 09:42 AM   #18
Jack Shaft
you need two,a side mount and a flywheel housing mount..you can use a conventional one for the fly housing..I used the water inlet boss and the pan rail for the side mount
Jack Shaft is offline   Reply With Quote
Old 01-09-2020, 12:24 PM   #19
Jim Brierley
I made mine similar to the one pictured by Mr. Shaft only on mine I attach the lower bolts to the top of the pan rail, this allows easy pan installation while on the stand. Don't worry about hanging the engine by the side, Ford did it that way. It also allows flywheel and clutch installation.
Jim Brierley is offline   Reply With Quote
Old 01-09-2020, 12:28 PM   #20
katy
katy's Avatar
you need two
What is your reasoning behind this statement? I've never had a problem using a side mount, but I use side mount that fastens to the top of the pan rail, not the bottom.
