Old 11-30-2019, 01:28 PM   #1
robert shreveport
Default Differences in 35 and 36 Ford Pick-up
Are there any differences in the body such as the fenders or doors? How can you tell the difference in the two year models? I’ve seen that the door mirrors are a different shape.
robert shreveport is offline   Reply With Quote
Old 11-30-2019, 03:39 PM   #2
flatford8
flatford8's Avatar
Default Re: Differences in 35 and 36 Ford Pick-up
I think the doors are the same...... ‘35 has a sharp crease by the bottom of the windshield post .... not sure about fenders..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 11-30-2019, 05:08 PM   #3
Brendan
Brendan's Avatar
the grill is wider on a 36 also the 36 has wide five wheals and the hood is different
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 11-30-2019, 06:21 PM   #4
derek costello
I have had both 35 and 36 ford pickups the 35 is a much better looking truck as the grill shell is not as deep (front to back) as a 36. The 35 has a nice slope to the grill as well, the ford v8 badge is on the middle side centre of the hood sides and at the front edge of the hood of the 36. The front edge of the hood is nearly straight up and down to match the grill shell edge unlike the 35 which is sloped back. So the hoods are not interchangeable unless you change the grill shell as well. The cabs are identical so is the box.
Ford made a much bigger radiator for the 36 truck this is why the changes in shells and hoods.
derek costello is offline   Reply With Quote
Old 11-30-2019, 07:13 PM   #5
robert shreveport
Derek I agree with you on-the 35 looking better. I just found a site on the internet showing differences in the 35 & 36. Real interesting.
Old 12-01-2019, 06:12 AM   #6
deuce lover
deuce lover's Avatar
Early '35's had inside garnish moldings for the doors,'36 no.A pillar at the cowl similar to '34 on the '35's.
deuce lover is offline   Reply With Quote
Old 12-01-2019, 07:22 AM   #7
oldandtired
The front fenders are not all the same. Some of the fenders have enclosed holes where the front bumper brackets pass through and some (most) have what amounts to a slot for the front bumper braces. I have been told that the fenders with the enclosed holes were early 35, which makes sense since the 37 pickup has the slotted type front fenders. The front fenders will interchange from 35-37 on the pickups. As Brendan pointed out, the 36 has the wide five artillery wheels and the 35 had wire wheels with a different bolt pattern. The 35 spare carrier is a one year design as a result with the 36 and 37 being different than the 35 due to the wide five.
oldandtired is offline   Reply With Quote
Old 12-01-2019, 08:50 AM   #8
flatford8
flatford8's Avatar
Robert.....can you post the link to that site you found?....thanks,...Mark
Old 12-01-2019, 09:45 AM   #9
robert shreveport
If I can figure it out let me try.
Old 12-01-2019, 09:56 AM   #10
robert shreveport
Flatheadford8 I have it bookmarked tell me how to share with you
Old 12-01-2019, 09:57 AM   #11
robert shreveport
https://www.jalopyjournal.com/forum/...masses.236409/
Old 12-01-2019, 10:00 AM   #12
robert shreveport
There’s a lot of info there, subtle changes, but it makes it easy to identify one from the other. If you have only the cab by itself you can tell what year it is. Even with no doors on it. Good pictures of the different grills also.
Old 12-01-2019, 10:43 AM   #13
flatford8
flatford8's Avatar
Thanks!....I have parts and pieces of 35-37....hope to put a ‘37 together with what I have....I like 35-36 better but I ended up finding more 37 stuff so that’s what it’s gonna be...Mark
Old 12-01-2019, 12:32 PM   #14
robert shreveport
Good deal, when you get it together post a couple picture.
Old 12-01-2019, 12:35 PM   #15
robert shreveport
Flatheadford8 what year cab are you gonna use. What about title for it?
Old 12-01-2019, 03:21 PM   #16
flatford8
flatford8's Avatar
I have a complete truck in ‘37 sheet metal....’38 car frame....motor/trans -rear end from a ‘37 car...’40 front end....patching the ‘37 cab with pieces from 35 & 36...this ain’t no restoration!!!!....more like a “Frankenstein truck”.....but I’m doing all the work and I’ll be happy with what it is when I’m done.....Maine isn’t a title state on vehicles older than 1995 I think......Mark
Old 12-01-2019, 10:32 PM   #17
Scott H in Wheaton
Scott H in Wheaton's Avatar
You aren't the only one with a Frankenstein truck...I have a 40 flathead in a 1938 car frame, a 1936 cab with a 1937 bed. It all works
Scott H in Wheaton is offline   Reply With Quote
