Old 10-28-2019, 12:12 PM   #1
FrankWest
FrankWest's Avatar
Default antifreeze?
Any good sources for Antifreeze-Coolant Propylene Glycol
Seems harder and harder to find.
Should I just use everyday antifreeze? Or does that really corrode the bearings?
FrankWest is offline   Reply With Quote
Old 10-28-2019, 12:18 PM   #2
qmdv
qmdv's Avatar
Default Re: antifreeze?
Walmart has the Propylene Glycol (the green stuff). Well at least for now. It may be totally outlawed in the future depending on who will be running things.
qmdv is offline   Reply With Quote
Old 10-28-2019, 01:03 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I bought some at our closest Walmart a few weeks ago.
John
Old 10-28-2019, 01:21 PM   #4
30aadoodlebug
30aadoodlebug's Avatar
QMDV,
I live in Massachusetts, and that post resonates a little too close to home. Went to the local Wally's a few months ago, and was shocked to pay $20.00 for two gallons of antifreeze. State DEP put a new tax on it. Thanks Granny Warren!
30aadoodlebug is offline   Reply With Quote
Old 10-28-2019, 01:41 PM   #5
Roger W Gerow
A little off topic but, does antifreeze have a shelf life? I have a couple of gallons that have been sitting on shelf for several years.
DD658
Roger W Gerow is offline   Reply With Quote
Old 10-28-2019, 01:45 PM   #6
1931 flamingo
1931 flamingo's Avatar
Smile Re: antifreeze?
$20 for TWO gallons is CHEAP ! ! Be Happy !
Paul in CT
Old 10-28-2019, 02:02 PM   #7
FrankWest
FrankWest's Avatar
the sierra antifreez sells for 25 dollars a gallon.
Old 10-28-2019, 02:15 PM   #8
50fordcoupeman
50fordcoupeman's Avatar
I dont believe it has a shelf life but you can always test it before you use to make sure.
50fordcoupeman is offline   Reply With Quote
Old 10-28-2019, 03:38 PM   #9
Ford Freak
Paul in CT
Yep , I sure would be !! Now , back to the OP 's question ...Will the yellow -ish stuff be ok , or do we need the green stuff in our flatty's ? - F F
Ford Freak is offline   Reply With Quote
Old 10-28-2019, 03:44 PM   #10
marko39
Paul in CT
Unless it's the 50/50 in which case you are buying water.
marko39 is offline   Reply With Quote
Old 10-28-2019, 04:06 PM   #11
FrankWest
FrankWest's Avatar
In a 1933 model B or a 1933 v8 engine are 5 gallons proper coolant fill? or should 4.5 gallons be used because over overfill/runnoff?
Old 10-28-2019, 04:51 PM   #12
50fordcoupeman
Here it is $10.89 a gallon concentrated so 50-50 mix makes it $5.45 a gallon usable.
Old 10-28-2019, 05:40 PM   #13
cas3
antifreeze actually does have a shelf life...sorta, in the big trucks they test it with some paper strips of some sort because it will get corrosive after 5 years or so. not sure if its from all the heating and cooling cycles, or a real shelf life.
Old 10-28-2019, 05:44 PM   #14
5851a
They have so many kinds on the shelf I'm about ready to go back to alcohol. 4 cars in garage, 3 of them Fords and 4 different requirements for antifreeze. Then you go to buy some and they sell gallons of "works in everything".
5851a is offline   Reply With Quote
Old 10-28-2019, 09:33 PM   #15
FlatheadTed
FlatheadTed's Avatar
delet
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-28-2019, 10:12 PM   #16
Roger/Sacramento
Roger/Sacramento's Avatar
Distilled water is $0.88/gal. here. That is what I use.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 10-28-2019, 11:06 PM   #17
RalphG
RalphG's Avatar
It is a bit confusing with how many colours of anti freeze there are now. Besides the old green, I have some red, some yellow. Some recommended for diesel engines. On light duty gas engines I've been using "recycled" anti freeze that I have changed out of my diesel engines. Left to settle and filtered several times it looks pretty good and still tests food for our severe cold winters.
RalphG is offline   Reply With Quote
Old 10-29-2019, 08:32 AM   #18
54vicky
54vicky's Avatar
just an aside the strips mentioned can be purchased at a swimming pool supply store.they are used to check pool PH works for anti freeze as well
54vicky is offline   Reply With Quote
Old 10-29-2019, 10:11 AM   #19
JT FORD
JT FORD's Avatar
I bought a gal. from NAPA this summer,cost around $25/00
JT FORD is offline   Reply With Quote
Old 10-29-2019, 07:35 PM   #20
T Scott
Regarding shelf life, I'm not sure about the anti corrosion properties but I recently drained the antifreeze out of a boat engine that was winterized 20 years ago. It was clean, still bright green and tested at -50F.
T Scott is offline   Reply With Quote
