Old 09-28-2019, 07:26 AM   #1
corndog
corndog's Avatar
Default Banjo wheel question?
I bought a nice banjo wheel that I thought was 37 Ford. But when I cleaned it up I discovered the center hub was chrome plated. The center has a keyed tapered hole like used on Fords. Could this be a Deluxe wheel or a Lincoln Zephyr wheel? Any help is appreciated! Corndog
Unspoken gratitude is helpful to no one.
corndog is offline   Reply With Quote
Old 09-28-2019, 07:40 AM   #2
Pat/Ohio
Pat/Ohio's Avatar
Default Re: Banjo wheel question?
Paul, The horn button/light switch looks very much like the one I had on a '35 3W, but the banjo appeared in '36 I believe. So I'm thinking it's a '36 banjo. Pat
Pat/Ohio is offline   Reply With Quote
Old 09-28-2019, 08:10 AM   #3
Zeke3
Zeke3's Avatar
x2 on 36, the round tie bars were used in 36.
Zeke3 is offline   Reply With Quote
Old 09-28-2019, 09:05 AM   #4
corndog
corndog's Avatar
Thanks!!!
Old 09-28-2019, 10:26 AM   #5
35fordtn
35fordtn's Avatar
It’s certainly 1936 Ford or 1936 Lincoln Both use the same but the horn button on the Lincoln does not have “v-8” molded into it
35fordtn is offline   Reply With Quote
Old 09-28-2019, 08:08 PM   #6
john stimac
john stimac's Avatar
The center hub on a 36 Lincoln Zephyr is chrome plated. The 36 Ford is not.
Other than that, they are the same
john stimac is offline   Reply With Quote
Old 09-29-2019, 10:26 PM   #7
Don Rogers
Don Rogers's Avatar
Early(2/13/36) drawings of the banjo wheel show a chrome plated hub. Later drawings show a Benton Gray hub and later a brown hub to match the wood grain dash.
Don Rogers is offline   Reply With Quote
