09-26-2019, 12:06 PM | #1 |
30-31 wheel well patch panel question
Was the L shaped flange on the bottom of the panel folded up to the sub rail or left L shaped? Thanks
09-26-2019, 12:19 PM | #2 | |
Re: 30-31 wheel well patch panel question
It was actually scalloped in several areas and was spot-welded to the Sill (Sub-rail). |
09-26-2019, 10:20 PM | #3 |
Post a picture of what your referring to.
06-09-2020, 09:28 PM | #4 | |
BRENT, Does someone make a "Correct" patch panel than has rolled beads that match factory beads. I want to repair mine, no desire to use the overlay full panel. If someone can roll a factory correct center bead on a 12x12 piece of steel that is another option. Thank you. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
06-10-2020, 10:05 AM | #5 | |
06-11-2020, 12:06 PM | #6 | |
I folded the L shaped flange at the bottom of the wheel well patch panel up to the sub rail . I felt that it was necessary . |
