#1 |
Hey folks! Very much a newbie here. I have a '29 Tudor with a Napa Commercial 7244 battery with a missing cap. I am trouble finding anyone who carries a replacement cap. Anyone have an idea of where I could find one? Thanks!
#2 |
I have several old batteries laying about but distance would make me sending you one unfeasable. A photo would help others wanting to help.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#3 |
Find a NAPA or other user friendly parts store. Usually they have a half ton of trade-in batteries to browse for caps.
Also most scrap metal places take batteries..... Good luck
'30 Coupe |
#4 |
Thanks. I tried Napa immediately (since it's Napa battery)..no go there. But I'll ask around.
#5 |
Go to a junkyard that recycles old batteries. They should have lots!!
#6 |
#7 |
So long as they fit, just find 3 the same from some other battery and screw them in. Done!
#8 |
I used a large rubber stopper from the local hardware store for years on my 6 volt battery. I even used a very small diameter plastic tube (from a carb cleaner spray can) for venting. A small V shaped cut on the side of the rubber stopper was added for the vent tube.
![]() Bob-A ![]() Skirts are for women not car fenders!
#9 |
Six and eight volt batteries use larger caps than the common twelve volt battery and always have as best as I remember . Good luck finding a cap or caps .
#10 |
Can you post a picture with a ruler nearby, is it push on or screw on--- if screw on is it 1/4 turn or threads--- pictures of cap and battery
#11 |
Looks like it is 1.25" in diameter at the top. It is a push-on, and the opening is 3/4". Any ideas would be awesome!
I can't get the pictures to load from a dropbox link.
Last edited by zaugger; 09-25-2019 at 08:39 PM. Reason: Pictures not showing up. |
#12 |
Sorry guys...clearly messing up this thread with my newbie posting skills. I cannot add pictures, but I'll try to find the correct way to upload them.
#13 |
[QUOTE=Bob-A;1802761]I used a large rubber stopper from the local hardware store for years on my 6 volt battery. I even used a very small diameter plastic tube (from a carb cleaner spray can) for venting. A small V shaped cut on the side of the rubber stopper was added for the vent tube.
![]() Bob-A ![]() Now THAT'S an interesting solution. Thanks for sharing! Chris |
#14 |
#15 |
I have an old battery in my garage. I can look at the caps and put a couple in the mail to you if I have your address.
#16 |
#17 |
Google could be your friend??
Paul in CT |
#18 |
#19 |
I just went on ebaymotors, parts and acc, 6volt battery bcaps and a couple of possibilities came up. FWIW
Paul in CT |
