Old 09-09-2019, 04:49 PM   #1
mrtexas
mrtexas's Avatar
Default Sticking float valve
Got a sticking float valve on my Ford 59 carb. Same as Stromberg 97? What is most reliable style of valve, current one is viton? Where to buy from?
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 09-09-2019, 05:01 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Sticking float valve
Get a solid brass needle. The rubber tipped ones have an issue with sticking.
Old 09-09-2019, 05:29 PM   #3
19Fordy
19Fordy's Avatar
Gross-Jet valves work very good. Just Google Gross-Jet valve.
Old 09-09-2019, 06:02 PM   #4
drolston
drolston's Avatar
Or S-Jet
Old 09-09-2019, 07:37 PM   #5
Kube
Super Moderator
Kube's Avatar
Yes they do until they don't. I would never again use one. I have had two to date stick closed.
Perhaps bad luck but when the second stuck closed, well, no more for me.
Old 09-09-2019, 07:39 PM   #6
scicala
scicala's Avatar
Does Gross-Jet make a float valve for a Ford/Holley 94 carb (model 59) ? I think that's what mrtexas has. Or are they made just for Stromberg carbs ? I have had good luck with solid steel needles, as Kube stated earlier.
Sal
Old 09-09-2019, 08:58 PM   #7
Pete
Everyone has an idea of what works best.
Go to the HAMB and type "float valves" in the search.
Enough reading to keep you busy for an hour.
Old 09-10-2019, 12:36 AM   #8
31Abone
31Abone's Avatar
May not be the float valve..might be the garbage gas like here in calif. had a lot of trouble with calif. gas sticking the float on 30's cars..pounding carb side helps sometimes... a bottle of carb cleaner helps....sc
31Abone is offline   Reply With Quote
Old 09-10-2019, 12:39 AM   #9
Tinker
Tinker's Avatar
Might be a combination of both. I agree with sal.
I'd refer to charlieNY, sal, and max.
Old 09-10-2019, 12:42 AM   #10
Tinker
Tinker's Avatar
A 59 holly is not anything like a 97 strom. Valve pressure stems are universal.
Old 09-10-2019, 10:20 PM   #11
3738
3738's Avatar
Tapped the 97 on my 38 Coupe with a small hammer and got it unstuck, working fine since
3738 is offline   Reply With Quote
